riton081
DEVERROUILLAGE COMMAND V2.0
Petit tuto pour avoir accès aux menus cachés
A LA PORTEE DU 1ER IMBECILE VENU (J'EN AI FAIT LA PREUVE)
COMAND UNLOCK V2.0 CONSOLE
The following cars are able to be unlocked with this manual:
CLS - W219
E CLASS - W211
SLK - R171
S CLASS W220 (WIDESCREEN)
SL R230 (WIDESCREEN)
This guide will allow you to enable the following features
View the TV while the car is moving
Play multi-regional disks and DVDRW
Enable mp3 playback
Modify other hidden features
INSRUCTIONS
1 Press the audio button to enter audio mode
2 To enter the engineering mode press the 1 mute, 2 phone and
3 serv buttons and hold for apx 45 seconds until you see a message saying “welcome to engineering mode”.
4 To enter the secret menu press and hold * button then the # followed by the < button and hold them all simultaneously.
5 To access the video in motion menu press the button next to Dr.Dist.
6 Using the arrow keys deactivate all of settings with the OK button. Your screen should now look like the photo below
Press the back button to go back to the main menu
7 To access the MP3 enabling menu press the button next to Backd.
Your screen should now look like the photo below –
Using the arrow keys, highlight the MP3 feature and enable it using the OK button.
Now go back to the main menu using the back button.
8 To access the DVD region menu, press the button next to regcod.
Using the arrow keys, highlight the region free setting and enable it using the ok button.
To activate the settings press back then end and switch the command console off then back on again.
All setting may be activated and de-activated as many times as you want.
Bon amusement :D
ml320cdi a écrit:
hé riton c'est bien mais je lis pas l'anglais moi,comment je fais avec mon gps
C'est de l'humour je suppose, relis mon titre et tu comprendras.
Regarder la Tv en roulant
Activer la lecture DVD RW (les DVD regravables)
Activer la lecture MP3
et d'autres trucs encore....(probablement l'accès à certains menus cachés)
Loulou a écrit:
Pas de TV, pas de DVD RW.
Mais il lit déjà les MP3 ce command !!! non ?
C'est qu'il est en partie déjà déverrouillé Shocked
Je ne sais pas s'il les lit par défaut, je n'ai jamais essayé, ni sur le ML, ni sur mon ex classe B.
Par contre, petite subtilité, car je crois que beaucoup font l'amalgame :
- quand tu graves des MP3 comme un "CD Audio" dans ton logiciel, ca les convertit en format audio classique. Il ne s'agit donc plus de MP3 à l'arrivée. Avantage: c'est lu par toutes les chaines hifi qui acceptent les CD gravés, idem pour les autoradios
- quand tu graves des MP3 comme un "CD de données" dans ton logiciel, ca conserve le format MP3 d'origine. Avantage : tu peux en mettre beaucoup plus sur un CD (un CD fait 650/700 Mo de capacité, et un MP3 fait 3 Mo en moyenne, ce qui te donne une capacité de stockage approximative de 230 titres, ce qui fait pas mal d'albums !). Inconvénient : ce n'est pas lisible par la plupart des lecteurs audios. Mais cette fonctionnalité semble débloquable sur le comand 2.5 (pas possible sur le Comand 2.0). Maintenant, si tu graves sur un DVD et plus sur un CD, sachant qu'un DVD a une capacité de 4.7 Go, fais le calcul.......tu peux embarquer toute ta bibliothèque sur une galette !
:D
:D
Benso, j'ai un command 2.0 sur ma 211 de 2003 et je lis les dvd et cd en mp3. DVD avec pour le moment +/- 900 morceaux
Je confirme, BEN a dit juste !!!
Pour mon tomtom qui lit les mp3 et les envoie en stéréo sur l'autoradio, j'ai acheté 2 cartes mémoires de 4GO et j'ai collé dessus TOUTE ma musithèque (plusieurs milliers de morceaux, et l'oeuvre symphonique complète de beethoven !!!! )
Ouai il a raison concernant la gravure en wav ou mp3 mais je confirme que le command 2.0 lit les mp3
:D
ton Comand ressemble à çà ?
Je pensais que les W211 étaient équipées avec le meme que sur les ML W164 et les classe B par exemple, y'a eu plusieurs équipements ?
:D
Je fait parfaitement la différence entre CD audio et CD Mp3 (de donnés), merci quand meme de le rappeler pour Roger sunny lol
Sans avoir fait aucune manip, le command (du w164) lit que le DVD navigation et un CD audio.
Le chargeur lit un CD audio et un CD Mp3 (de donnés). Mais après je vais vais voir si le command lit les DVD (de donnés) Mp3 (qui ne permettra pas d'emmener ma bibliothèque) Crying or Very sad
:D
Non, le mien c'est le même que celui qui illustre le tutto
Loulou a écrit:
Le command 2.0 (comme celui de bocky) ne lit pas les Mp3.
C'est sûr, les mp3 n'existaient pas à l'époque, son command lit les cassettes Sad
:D
Riton, le tien est donc un Comand APS NTG 1 sunnysunny
:D
Ah et bien voilà l'explication, moi je me fiais au titre du tutto que j'avais pompé. Oui je suis Belge, je sais, je sais. Embarassed
Je dit ça parceque tu disais que tu avais le 2.0 et qu'il lit les Mp3.
Donc c'est quoi ne nom du command qui illustre le tuto ?
Tu peux faire quoi en plus ?
Riton : j'ai eu un énorme doute, j'ai fait le tour des différents sites, et j'ai trouvé l'info sur celui d'un ami alsacien spécialiste de ces systèmes sunny Je te donnerai bien le lien, mais je sais pas si tu pourras accéder Sad
J'ai un Oncle Breton, ami de Potret, et qui m'aime bien, qui me laissera sûrement accéder à ce site Rolling Eyes
Chiche ! sunny
bensoltane a écrit:
Chiche ! sunny
Et bien voila que je ne trouve plus l'adresse maintenant, même pas dans mes favorits, bizarre bounce
