Honda B séries
C'est juste un copié collé de ce que j'ai trouvé sa peut toujours servir par contre ne tenez pas compte des dates se sont les sorties américaines apparemment :
B16
JDM B16A (First Generation)
The first VTEC engine Note: All JDM B16A engines are stamped 'B16A' (with no number after the "A" to identify version).
  • VTEC
  • Found in:
  • 1988-1991 JDM Honda Integra RSi/XSi (DA6/DA8)
  • 1989-1990 JDM Honda CRX SiR (EF8)
  • 1989-1990 JDM Honda Civic SiR (EF9)
  • Displacement: 1,595 cc (97.3 cu in) 1.6 liter
  • Compression: 10.2:1
  • Bore: 81.0 mm (3.2 in)
  • Stroke: 77.4 mm (3.0 in)
  • Rod Length: 134 mm (5.3 in)
  • Rod/stroke ratio: 1.745
  • Power: 160 PS (118 kW; 158 hp) @ 7,600 rpm & 15.5 kg·m (152 N·m; 112 ft·lbf) @ 7,000 rpm
  • Redline: 8100 rpm
  • Transmission: S1/J1/YS1 (4.4 final drive), Y1 (4.266 final drive, cable clutch, optional LSD)
  • ECU code: PR3-003 (DA6/DA8), PW0-000 (EF8/EF9/DA6)
  • ODB0
</li>
</li>
JDM B16A (Second Generation)
  • Found in:
  • 1991-1994 JDM Honda Civic Sir/SiRII (EG6)
  • 1991-1993 JDM Honda Civic Ferio SiR (EG9)
  • 1992-1995 JDM Honda CRX Delsol SiR (EG2)
  • 1995-1998 JDM Honda Civic Sir/SiRII (EK4)
  • 1995-1998 JDM Honda Civic Ferio Si (EK4)
  • Compression: 10.4:1
  • Power: MT: 170 PS (125 kW; 168 hp) @ 7,800 rpm & 16.0 kg·m
    (157 N·m; 116 ft·lbf) @ 7,300rpm (AT: 160 PS (118 kW; 158 hp) @ 7,300
    rpm & 15.6 kg·m (153 N·m; 113 ft·lbf) @ 6,500rpm)
  • Redline: 8200 rpm (AT: 7700 rpm)
  • Transmission: S4C/Y21/S21 (4.4 final drive, optional LSD)
  • ECU code: P28 (EG2), P30 (EG2/EG6)
  • ODB1/ODB2
</li>
</li>
B16B (Type R)
  • VTEC
  • Found in:
  • 1997-2000 JDM Civic Type R[EK9]
  • Compression: 10.8:1
  • Bore: 81 mm (3.2 in)
  • Rod/Stroke ratio: 1.84:1
  • Rod Length: 142.42 mm (5.6 in)
  • Power: 136 kW (185 PS; 182 hp) @ 8200 rpm & 16.3 kg·m (160 N·m; 118 ft·lbf) @ 7500 rpm
  • Redline: 8400 rpm
  • Rev-limit: 9000 rpm
  • Transmission: S4C With Helical LSD (4.1 final drive, dual-synchromesh on 2nd, 3rd and 4th gears)
  • Vtec engagement @ 5800 rpm
  • ECU code: PCT
</li>
</li>
  • Note: This engine uses the same block as the Integra Type R
    (B18CR), which is taller than the B16a block (by approx 17mm), but with
    a crank the same stroke as the b16a. It uses longer rods to accommodate
    for this, which is why the Rod/Stroke ratio is higher than a standard
    B16.
B16A1
  • VTEC
  • Found in:
  • Early Integra, CRX, Civic'1.6i-VT'(EE8)(EE9)
  • Displacement: Template:Convert/aa 1.6 liter (1595)
  • Bore×Stroke: 81.0×77.4 mm (3.19×3.05 in)
  • Power: 150 hp (112 kW) @ 7600 rpm
  • Torque: 106 lb·ft (144 N·m) @ 7100 rpm
  • Redline: 8000 rpm
  • Transmission: Y2
  • aluminium casting
</li>
</li>
B16A2
  • VTEC
Found in:
  • 1992-2000 Honda Civic EDM VTi (EG6/EG9 & EK4)
  • 1992-1997 Honda Civic Del Sol EDM VTi (EG)
  • 1996-1997 Honda Civic Del Sol USDM "VTEC"
  • 1999-2000 Honda Civic USDM Si (EM1)
  • 1999-2000 Honda Civic CAN SiR (EM1)
  • Power: 160 hp (119 kW) @ 7600 rpm & 111 lb·ft (150 N·m) @ 7000 rpm
  • Transmission: Y21 or S4C
  • Redline...8000 rpm
  • Rev Limit...8450 rpm
  • VTEC Engagement...5,500 rpm
  • aluminium casting
</li>
</li>
B16A3
  • VTEC
  • Found in:
  • 1994-1995 Del Sol VTEC
  • Displacement 1,595 cc (97.3 cu in)
  • Power: 160 hp (119 kW) @ 7,600 rpm & 118 ft·lbf (160 N·m) @ 7,500 rpm
  • Redline: 8,200 rpm
  • Transmission: Y21
</li>
</li>
B16A4
  • VTEC
  • Found in:
  • 1996-2000 Civic Si-RII (EK4)
  • Power: 125.04 kW (170 PS; 168 bhp) @ 7800 rpm & 111 ft·lbf (150 N·m) @ 7300 rpm
  • Redline: 8200 rpm
  • Transmission: Y21
</li>
</li>
  • Note: Only offered with SiRs with manual tranmissions.
B16A5
  • VTEC
  • Found in:
  • 1996-2000 Civic Si-RII (JDM version) (EK4)
  • Power: 130 kW (177 PS; 174 bhp) @ 7800 rpm & 111 ft·lbf (150 N·m) @ 7300 rpm
  • Redline: 8000 rpm
  • Transmission: Y21
</li>
</li>
  • Note: Only offered with SiRs with automatic transmissions.
B16A6
  • VTEC
  • Found in:
  • 1996-2000 Honda Civic - South Africa VTEC (EK)
  • Power: 118 kW (160 PS; 158 bhp)
</li>
</li>
B17
B17A1
  • VTEC
  • Found in:
  • 1992-1993 Integra GS-R (DB25)
  • Displacement: 1,678 cc (102.4 cu in)
  • Bore: 81 mm (3.189 in)
  • Stroke: 81.4 mm (3.205 in)
  • Rod/Stroke Ratio: 1.63
  • Rod Length: 132.28 mm (5.208 in)
  • Compression: 9.7:1
  • Power: 160 hp (120 kW) @ 7600 rpm & 118 ft·lbf (159 N·m) @ 7000 rpm
  • Came equipped with the YS1 cable trans, which was different than
    other cable B-series transmissions as it has a different input shaft.
</li>
</li>
B18
B18A
The B18A is not considered part of the modern B-series family. This engine shares many characteristics with the B20A/B21 See Honda B20A engine.
  • Non-VTEC
  • Found in:
  • 1986-1989 Accord Aerodeck LXR-S/LX-S (Japan)
  • 1986-1989 Accord EXL-S/EX-S (Japan)
  • 1986-1989 Vigor MXL-S (Japan)
  • Displacement: 1,834 cc (111.9 cu in)
  • Compression: 9.4:1
  • Stroke: 89 mm (3.5 in)
  • Dual Keihin Carbs
  • Power: 100 hp (75 kW) @ 6100 rpm & 128 lb·ft (174 N·m) @ 4700 rpm
  • Transmission: A2N5, E2N5
</li>
</li>
B18A1
  • NON -VTEC
  • Found in:
  • 1990-1993 Acura Integra usdm "RS/LS/GS" (DA9, DB1)
  • Compression: 9.2:1
  • Rod Length: 137.01 mm (5.394")
  • Rod/Stroke Ratio: 1.54
  • Redline: 6500 rpm
  • Rev Limiter: 7200
  • Programmed fuel injection
  • Power: 90-91 Only: 130 bhp (97 kW) @ 6000 rpm & 121 ft·lbf (164 N·m) @ 5000 rpm
  • Power: 92-93 Only: 140 bhp (100 kW) @ 6300 rpm & 126 ft·lbf (171 N·m) @ 5000 rpm
  • Transmission: 90-91: A1,S1, cable
  • Transmission: 92-93: YS1, cable
</li>
</li>
B18B1
  • NON-VTEC
  • Found in:
  • 1994-2001 Acura Integra "RS/LS/GS/SE" (DC4/DB7)
  • Power: 142 hp (106 kW) @ 6300 rpm & 127 ft·lbf (172 N·m) @ 5200 rpm
  • Redline: 6800 rpm
  • Rev Limit: 7200 rpm
  • Transmission: Y80/S80
</li>
</li>
B18B4
  • NON-VTEC
  • Found in:
  • 1996-2000 Honda Ballade 180i
  • Rod Length: 137.01 mm (5.394 in)
  • Power:
  • Redline: 7200 rpm
  • 142 hp (106 kW) @ 7000 rpm & 127 ft·lbf (172 N·m) @ 5200 rpm
</li>
  • Transmission: Y80/4254245
  • </li>
    </li>
    JDM B18C
    SPEC R
    • VTEC
    • Found in:
    • 95-00 JDM Honda Integra Type R DC2
    • 95-00 JDM Honda Integra Type R DB8
    • Rev-limit: 8600 rpm
    • Power: 200 PS (147 kW; 197 hp) @ 8000 rpm & 17.5 kg·m (172 N·m; 127 ft·lbf) @ 7500rpm (96 spec) 18.5kgm @ 6200 rpm (98 spec)
    • Transmission: S80 with Helical LSD
    • S80 spec: J4D (96specR & 4.4 final drive), N3E (98specR & 4.785 final drive)
    • Displacement: 1,797 cc (109.7 cu in)
    • Compression: 11.1:1
    • Stroke: 87.2 mm (3.4 in)
    • Rod Length: 137.9 mm (5.4 in)
    • Rod/Stroke Ratio: 1.58
    • VTEC Engagement @ 5800 rpm
    • ECU code: P73-003 (96specR) P73-013 (98specR)
    </li>
    </li>
    (Source: BMI Vol.1 Type R Legend)
    SiR/GSR
    • VTEC
    • Found in:
    • 93-95 JDM Honda Integra Si (DB8, DC2)
    • 95-98 JDM Honda Integra SiR/SiR II (DB8, DC2)
    • 98-99 JDM Honda Integra SiR-G (DB8, DC2)
    • Identification: Black valve cover with dual runner intake manifold
    • Rev-limit: 8000 rpm
    • Power: 132.39 kW (180 PS; 178 bhp) @ 7200 rpm & 128 ft·lbf (174 N·m) @ 6200 rpm
    • Compression: 10.6:1
    • ECU code: P72
    </li>
    </li>
    Highlights of B18C Spec R compared to standard B18C GSR
    1. Camshaft - Wide-angled, high-lift, high-durability camshaft
    2. Exhaust Valve Spring - High-lift, dual-layered spring
    3. Spark plug - High-heat-type #7 platinum plug
    4. Engine Stiffener - Aluminum die-cast, high-durability, one-piece type
    5. Crankshaft - Full-counterweight, 8-weight, high-output, custom crankshaft
    6. Connecting Rod - Custom TypeR rod, high-durability, lightened
    7. Pistons - High-compression, low-friction, custom pistons
    8. Inlet Valves - Lightened inlet valves
    9. Intake Manifold - Custom tuning, single-port type.
    10. Throttle Body - 62 mm (2.4 in) wide-mouth throttle body.
    11. Inlet Valve Springs - High-lift, flat-surfaced, dual-layered spring
    12. Port Buffing done by hand
    13. Fastening of Connecting Rod done with micrometer. Even though all
    engine component parts are done by a micrometer and not eye balled.
    14. All stainless steel headers
    B18C1
    • VTEC
    • Found in:
    • 1994-2001 USDM Integra GS-R (DC2/DB8)
    • Compression: 10.0:1
    • Power: 170 hp (127 kW) @ 7600 rpm
    • Torque: 128 lb·ft (174 N·m) @ 6200 rpm
    • Redline: 8100 rpm (Fuel cut-off @ 8200 rpm)
    • VTEC Engagement @ 4400 rpm
    • Transmission: Y80(No LSD) 5-Speed Manual Transaxle
    </li>
    </li>
    B18C2
    • VTEC
    • Found in:
    • 1994-1999 Honda Integra VTi-R
    • AUDM Spec 1993-1999 Honda Integra VTi-R
    • Compression: 10:1
    • Power: 168 hp (125 kW) @ 7600 rpm
    • Redline: 8200 rpm
    • Fuel Cut: 8300 rpm
    </li>
    </li>
    B18C3
    • VTEC
    • Found in:
    • 1995-1998 Honda Integra Type R
    </li>
  • Power: 193 PS (142 kW; 190 hp) @ 8200 rpm & 127 lb·ft (172 N·m) @ 7500 rp
  • B18C4
    • VTEC
    • Found in:
    • 1996-2000 UK Civic 1.8i VTi 5-door Hatch (MB6)
    • 1996-2000 UK Civic 1.8i VTi-S (Limited Edition) 5-door Hatch (MB6)
    • 1996-2000 UK Civic Aerodeck 1.8i VTi 5-door Wagon (MC2)
    • 1998-1999 EU Civic Aerodeck 1.8i VTi 5-door Wagon (MC2)
    • 1998-1999 EU Civic 1.8i VTi 5-door Hatch (MB6)
    </li>
  • VTEC engagement@4,400 rpm
  • IAB open@5,750 rpm
  • Power: 169 hp (126 kW) @ 7600 rpm & 117 lb·ft (159 N·m) @ 6200 rpm
  • Limit: 8,100 rpm
  • Transmission: S9B w/Torsen LSD.
  • 0/100 km/h : 7.9 seconds (8.5 Aerodeck)
  • B18C5
    • VTEC
    • Found in: USDM DC2 Acura Integra Type-R (Integra Type-R)
    • 1997-2001 Integra Type-R (**Note: This model was not produced for the 1999 production year)
    </li>
    • Power: 195 hp (145 kW) @ 8000 rpm & 130 ft·lbf (180 N·m) @ 7300 rpm
    • Redline: 8400 rpm (Fuel cut-off @ 8500 rpm)
    • VTEC Engagement @ 6000 rpm
    • Transmission: S80 w/LSD
    B18C6
    • VTEC
    • Found in:
    • 1998-2001 Honda Integra UK and Euro Spec Type R
    </li>
  • Type: 1.8 litre 16v DOHC 4 cylinder in-line
  • Air intake diameter: 62 mm (2.4 in)
  • Power: 190 PS (140 kW; 187 hp) @ 7900 rpm & 131 lb·ft (178 N·m) @ 7300 rpm
  • Redline: 8400 rpm
  • Rev-limiter: 8700 rpm
  • Vtec engagement: 5700 rpm
  • B18C7
    • VTEC
    • Found in:
    • 1999 - 2001 Honda Integra Type R (Australia)
    </li>
  • Power: 193 PS (142 kW; 190 hp) @ 8200 rpm & 127 lb·ft (172 N·m) @ 7500 rpm
  • B20
    B20B
    • 1996-1998 specs
    • NON-VTEC
    • Found in: USDM and JDM Honda CR-V, Honda Orthia
    • Displacement: 1,973 cc (120.4 cu in)
    • Power: 126 hp (94 kW)) @ 5400 rpm
    • Torque: 131 ft·lbf (178 N·m) @ 4300 rpm
    • Rod length: 137 mm (5.4 in)
    • Compression: 8.8:1 or 9.2:1
    • Bore: 84 mm (3.3 in)
    • Redline: 6300 rpm
    B20B/B20Z
    • 1999 - 2000 specs
    • NON-VTEC
    • Found in: USDM CRV as a B20Z, JDM Honda CR-V and Honda Orthia as a B20B
    • Power: 146 hp (109 kW)) @ 6200 rpm
    • Torque: 133 ft·lbf (180 N·m) @ 4500 rpm
    • Rod length: 137 mm (5.394 in)
    • Compression: 9.6:1
    • Redline: 6700 rpm
    B20A/B21A
    The B20A3 and B20A5 are not considered part of the B family. See Honda B20A engine.
    B Series Transmissions
    Note: All B series Transmissions are interchangeable. YS1 casing can
    take S80 Internals or a hydraulic conversion kit can be used to operate
    hydraulic transmissions in cable operated models.
    J1/S1
    • Found in: Integra XSI/RSI (DA6)
    • Type: Cable
    • 1st: 3.230
    • 2nd: 2.105
    • 3rd: 1.458
    • 4th: 1.00
    • 5th: 0.848
    • R: 3.000
    • FD: 4.400
    S1/YS1
    • Found in: 1990-93 USDM Integra LS/RS (DA)
    • Type:cable
    • 1st: 3.230
    • 2nd: 1.901
    • 3rd: 1.269
    • 4th: 0.966
    • 5th: 0.742
    • R: 3.000
    • FD: 4.266
    Y1
    • Found in: CRX/Civic (optional LSD)
    • Type: Cable
    • 1st: 3.166
    • 2nd: 2.052
    • 3rd: 1.416
    • 4th: 1.103
    • 5th: 0.870
    • R: 3.000
    • FD: 4.266
    YS1
    • Found in: Integra 92-93 XSI/RSI (DA6, DA9)
    • Type: Cable
    • 1st: 3.307
    • 2nd: 2.105
    • 3rd: 1.458
    • 4th: 1.107
    • 5th: 0.880
    • R: 3.000
    • FD: 4.400
    S80
    • Found in: Integra Type R 98+ (LSD)
    • Type: Hydraulic
    • 1st: 3.230
    • 2nd: 2.105
    • 3rd: 1.458
    • 4th: 1.034
    • 5th: 0.787
    • R: 3.000
    • FD: 4.785
    S80/Y80
    • Found in: JDM SiR-G (optional LSD) / 94+ USDM GS-R (no LSD)
    • Type: Hydraulic
    • 1st: 3.230
    • 2nd: 1.900
    • 3rd: 1.360
    • 4th: 1.034
    • 5th: 0.787
    • R: 3.000
    • FD: 4.400
    S9B
    • Found in: EDM UKDM MB6 (LSD)
    • Type: Hydraulic
    • 1st: 3.230
    • 2nd: 1.900
    • 3rd: 1.360
    • 4th: 1.034
    • 5th: 0.8
    • R: 3.000
    • FD: 4.266
    Y21/Y80/S80/S4C
    • Found in:
    • JDM 96-97 Integra R(LSD)
    • JDM Civic R [EK9](LSD)
    • JDM Civic SiR [EK4, EG6]
    • JDM CR-X DEL SOL SIR (EG2)(optional LSD)
    • USDM DEL SOL VTEC (EG2)(OPTIONAL LSD)
    </li>
  • Type: Hydraulic
  • 1st: 3.230
  • 2nd: 2.105
  • 3rd: 1.458
  • 4th: 1.107
  • 5th: 0.848
  • R: 3.000
    • FD: 4.400
    Mets ta source, Toopil,
    Toujours quanf c'est pas une info de toi. sauf si tu c'est vraiments pas qui c'est
    Je pense que c'est wikipédia si tu cliques sur un des liens plus haut ça te renvoie sur wikipédia a la page correspondante.
    De plus c'est bien le style de wikipédia pour mon moteur aussi il méttait les rapports de ponts selon le modèle/motorisation
    EG6 JDM = Sir/SirII
    B16A2
    Année: 1992-2000
    Cylindrée: 1 595 cm3
    Puissance et régime d'obtention: 160 ch à 7600 tr/min
    Couple et régime d'obtention: 150 Nm à 7000 tr/min
    Alésage: 81 mm
    Course: 77,4 mm
    Rapport volumétrique: 10.2:1
    VTEC: oui
    OBD1 (1992-1996) et 2 (1996-2000)
    ECU: P30 (EG2/EG6/EG9), P2T, P2S (EK4)
    Véhicule:
    1992-2000 EDM Honda Civic VTi (EG6/EG9 & EK4)
    1992-1997 EDM Honda CR-X del Sol EDM VTi (EG2)
    1996-1997 USDM Honda CR-X del Sol VTEC (EG2)
    1999-2000 USDM Honda Civic Si (EM1)
    1999-2000 CAN Honda Civic SiR (EM1)
