Tim
Pour Umul (et les autres) : Maquette MX5 sur base Tamiya RC 1/10ème
Un travail hallucinant !
Vue la : http://www.scale4x4rc.org/forums/showthread.php?t=4399
I managed to finally upload and re-size most of the build pics of the Miata. I apologize for the sheer number of photos but I tried to include as many as possible so as to share some more ideas with all. I hope you find something of interest or help you with ideas as you slog through them Very Happy
NOTE: They're roughly in chronological order. On some aspect of the build, I've gone back and re-worked a particular detail. A good example is the driver figure.
The running chassis is a Tamiya M02 built as an RWD with the medium nosebox. The chassis is extremly versatile as it can be configured as FWD, RWD or even 4WD (with two drive units) and the wheelbase is adjustable by using different lenght noseboxes. The Miata was built to comply with TCS Rules for Best of Show and is fully functional.
'tain mais c'est hallucinant Shocked
Le mec gère à mort !
Coup de coeur pour la baie moteur amen
hallucinant,moi qui etait fier de mon rx7 ,chassi tt01 de chez tamyia,je crois que j'ai encore du boulot et je suppose qu'en cas de casse,il lui suffit simplement de retirer la coque. : :cartonne:
