Sylvain891
document sur rs turbo 43/80pages en ligne
j ai trouve un manuel en anglais
toujours en anglais dommage qu il existe rien en francais
The Ultimate RS Turbo!!
Technical and Tuning Guide!!
This guide has everything you will ever want to know about your RS!
Buying the car, servicing, repairing, fault finding, modifying and tuning, including fitting your own 2 stage boost controller, rear disc conversion and GRS Intercooler!!
This guide is aimed at the Escort RS Turbo but the majority of the technical information also applies to the Fiesta RS Turbo as the engines and setups are almost identical!
80 Pages!! 38 Sections!!
1. Starting problems
2. Air leaks
3. Oil leaks
4. Water leaks
5. Brakes
6. Servicing
7. Cold starting problems
8. Electrical problems
9. Smoking
10. Rust proofing
11. Bumps and vibrations
12. Boost problems
13. Misfires
14. Dump valve fitting
15. Cam followers
16. Overheating
17. What petrol?
18. D.I.Y Two stage boost
19. Fitting a boost gauge
20. Chip identification in ECU
21. Rear disc conversion
22. Cleaning after market air filters cheaply
23. Changing valve stem oil seals the easy way
24. ABS removal
25. Water injection – what is it?
26. Lowering your ACT
27. Gearbox replacing and linkage overhauling
28. Bodykit removal and refitting
29. Sensors and their location
30. 90 spec – list of changes
31. List of all bushes on car
32. Paint codes for all series 2 cars
33. Bailey swirl pot – fitting instructions
34. Bailey breather – fitting instructions
35. Pace charge cooler – fitting instructions
36. GRS intercooler – fitting instructions
37. ACT gauge – fitting instructions
38. Buying guide for the Series 2 (1986 – 1991)
bientot je mettrais les pages en francais quand j aurai retrouve ma traductrice
donc ca sera en anglais bientot pour patienter
J'espère surtout qu'elle aime la mécanique sinon elle va prendre chère la pauvre.
elle aime bien m aider dans mes recherches
sinon je vais voir le voisin des bo parents c des anglais est vive en france est aime bien ma petite cab donc je vais essaye de leur glisse le document complet pour qu il puisse m aider eux aussi
comme promis je mets en ligne le livre sur rsturbo
desole du retard petit soucis d internet
voici deja 1er episode des 80 pages
bonne lecture
l'ami sylvain,toujours la pour ttes les meilleures choses
eh oui
vivement quel tourne ma turbal pour me faire plaisir et prendre de bonne sensation
en attentant je recupere document qui parle sur rs turbo et despieces gain de puissance et amelioration de la resto
