aurelien10 0 Posté(e) le 2 juin 2009 YES YES YES YES YES YES !!!! Depuis le temps que j'en parlais avec JR , elle est ENFIN LA !!!! :supdbl: AEM’s Series 2 Programmable Engine Management System is more powerful than its predecessor. In addition to more robust hardware, there are several improvements over the original EMS, noted in the chart below. Like its predecessor, AEM's Series 2 Plug & Play EMS plugs directly into a vehicle's factory ECU harness and requires no additional wiring or hardware. Windows compatible software (2000, XP, NT, 98, 95, ME) makes the task of copying, viewing and manipulating data as simple as a click of the mouse. Our new AEMTUNER software is infinitely adjustable software and allows tuners to program virtually any combination of engine control, power adders and auxiliary devices, and accurately delivers proper amounts of fuel and correct ignition timing for any boost level or operating condition. SERIES 2 KEY FEATURES * Plugs directly into the factory harness. No rewiring necessary. * Uses all the factory sensors. * Includes start up calibrations. * System is fully enabled and unlocked - Never pay for upgrades! * Context sensitive help eases tuning process. * Maps can be password protected by the tuner to prevent unauthorized usage or sharing. * Runs on Windows-compatible software. * 12 peak and hold injector drivers (Supra only). * 8 direct-fire coil outputs. * 16 general-purpose outputs. * 8 definable switch inputs. * 4 EGT inputs with fuel control. * 1MB of internal data logging. * Electronic boost control. * Full idle control. * Programmable traction control. * Software definable knock control. * Two step launch control. * User configurable soft-cut rev limiters. * Wet or dry nitrous control. * Tune using new USB communication port or serial port. * Works with all AEM gauges. ECU Comparison Table* Series1 Series2 Outputs Injector outputs 10 12 Ignition outputs 5 8 General purpose LS outputs 12 12 General purpose HS outputs 4 4 Individual cylinder ignition trims Yes Yes Individual cylinder fuel trims Yes Yes Inputs Trigger inputs (Ref/Sync) 3 3 Analogue voltage inputs 12 12 Analogue temperature inputs 6 6 Switch inputs 6 6 Lambda inputs 2 x 2 x Internal barometric pressure sensor Yes Yes Knock sensors 2 2 User adjustable knock sensor center frequency No Yes Communication USB No Yes CAN No 2 Ch RS232 Yes Yes Data Acquisition Internal data logging 512 kB 1 MB Maximum internal logging rate (per channel) 250 Hz 250 Hz PC logging Yes Yes Data analysis using AEMLog Yes Yes Functions and Features Boost control Yes Yes Groundspeed based boost target Yes Yes Nitrous injection Yes Yes Staged injection Yes Yes Ground speed limiting Yes Yes Traction and launch control Yes Yes Overrun boost enhancement (anti-lag) Yes Yes Gear change ignition cut (shift-without-lift) Yes Yes Stepper motor idle control Yes Yes Continuously variable cam control 2 cams 4 cams Drive by wire throttle control PnP Only PnP Only Password protected calibrations No Yes Main Relay control Yes Yes VTEC Control Yes Yes Fuel & Ignition rev limiters Yes Yes "In-cockpit" global fuel trim capability Yes Yes Gear dependant shift light Yes Yes Evap/Purge Function Yes Yes DC Motor control 2 Ch 2 Ch Software definable switch inputs 1 2 EGT Based fuel trims Yes Yes Maximum boost limit None None Automatic transmission control Yes Yes Bien sur il y a un nouveau soft !!! Bref , j'ai hâte de tuner ma première V2 Partager ce message Lien à poster Partager sur d’autres sites
Fred2211 0 Posté(e) le 2 juin 2009 il y a pour Gt de 99 2000 ?? Partager ce message Lien à poster Partager sur d’autres sites
aurelien10 0 Posté(e) le 2 juin 2009 En universel ouais . En PNP non . Chez motec oui . Partager ce message Lien à poster Partager sur d’autres sites
