Cryl-5051 0 Posté(e) le 8 octobre 2005 Une mamie bien bichonnée !!! et qui doit marcher très très fort je pense.... Partager ce message Lien à poster Partager sur d’autres sites
Mpower238 0 Posté(e) le 8 octobre 2005 Superbe! Tu as plus de details concernant la bete? Partager ce message Lien à poster Partager sur d’autres sites
Cryl-5051 0 Posté(e) le 8 octobre 2005 Env 700ch..... la vache!! BODY: New OEM Doors, Hood, Trunk Custom Frame Rails/Diff Mounts/Transmission Mount Factory Undercoating Eight coats European Onyx Black Five Coats Glasurit Clear...hand rubbed (painted by Southside Auto Body) BMP Body Kit Every Seal Replaced INTERIOR: 1995 M5 Grey Leather Seats Anthercite Carpet European Headliner Full Leather Door Panels Custom Wood-Work Sony 200watt Sound System VDO Gauge Cluster--oil pressure, boost, oil temp EGT, DUAL AFR Gauges, Knock Warning Dash Mounted Trim Dials: turbo boost, fuel mixture, ignition timing SUSPENSION, BRAKES AND WHEELS Coil-Over Adjustable Suspension Urethane bushings and links Heavy duty sway bar Camber adjustable Factory four piston calipers Vented rotors, front and rear Steel braided brake lines Euro racing pads BF Goodrich KD front and rear BBS 3peice racing rims, custom titanium bolts Race Prepared Differential OEM BMW key wheel locks ENGINE: Race Prepared M90 Engine Block "O" Ringed Block and Head Custom made Shrick Turbo Cam Custom made JE Forged Turbo Pistons JE Rings Special Total Seal/JE Rings Race Prepared Forged Crankshaft Custom made Crower Rods, H-Beam design, Forced Pin Oiling 300,000psi Super-Alloy Rod Bolts Raceware Head Studs Raceware Main Caps BMW Motorsport Rockers Billet Rocker Retainers Stainless Steel Valves Dual Racing Valve Springs Teflon Seals Stainless Head Rings Titanium Retainers Dual-Row Adjustable Cam Gear high Output Oil Pump--50psi Idle Crankfire Ignition System Race Prepared Flywheel Race Prepared Cylinder Head Stainless Steel Braided Lines/Anodized Fittings Custom Racing Billet Oil Cooler Fasteners--Stainless or Anodized Billet Aluminum or Titanium Sachs Dual Disc Racing Clutch Getrag 5 speed TURBO: Limit Engineering Race Prepared Turbo BMW Turbo Exhaust manifold Custom 46mm Multi Chamber Billet Wastegate Haltech E11 32bit ECU Magnecor 10mm Race Wires NGK Iridium Spark Plugs Aquamist Methanol Injection System APC Knock Sensing System Balanced RC Stainless Injectors SX fuel Pressure Regulator SX Check System Bosch Motorsport External/Internal Racing Fuel Pumps Dual Feed Fuel Rail Dual Stainless 3" Exhaust System (side exits) Custom Spearco Water/Air Intercooler Adjustable Blow-off Valve Many parts chrome plated Partager ce message Lien à poster Partager sur d’autres sites
Mpower238 0 Posté(e) le 8 octobre 2005 Merçi!! Partager ce message Lien à poster Partager sur d’autres sites
BOBO635 0 Posté(e) le 9 octobre 2005 Oulalalalaaaaa.... caisse qu'elle est bellleeeee !!!!! Partager ce message Lien à poster Partager sur d’autres sites
2NI-bavaria-motors 0 Posté(e) le 9 octobre 2005 Et bé... Partager ce message Lien à poster Partager sur d’autres sites
