Raf Istole1
BMW OEM (Moteur) En cours
Engine
1-Remanufactured short engine 11 00 1 727 467 €2884.35 / $4216.63
2-Set Mounting Parts Short Engine 11 00 9 059 259 €41.30 / $60.38
Engine housing
1-Supporting bracket left 11 81 1 132 777 (X1) €21.40 / $31.28
2-Supporting bracket right 11 81 1 132 776 (X1) €21.40 / $31.28
3-Hex Bolt with washer 07 11 9 901 499 M8X26-Z1-ZNS (X3) €0.24 / $0.35
4-Hex Bolt with washer 07 11 9 901 499 M8X26-Z1-ZNS (X4) €0.24 / $0.35
5-Rubber mounting 11 81 1 137 076 (X2) €47.70 / $69.73
6-Heat resistant plate 11 81 1 137 053 (X1) €3.07 / $4.49
7-Wave washer 07 11 9 932 112 B10-ZN (X2) €0.05 / $0.07
8-Hex nut 07 11 9 915 558 M10 (X2) €57.00 / $83.33
9-Wave washer 07 11 9 932 112 B10-ZN (X2) €0.05 / $0.07
10-Hex nut 07 11 9 915 558 M10 (X2) €57.00 / $83.33
11-Heat resistant plate 11 81 1 137 771 Left-hand drive (X1) €9.15 / $13.38
12-Hex Bolt with washer 07 11 9 913 429 M6X10-Z2 Left-hand drive (X1) €0.10 / $0.15
1-Engine block with piston 11 11 1 739 588 (X1) €1470.00 / $2148.99
Only in conjunction with
· Non-return valve 11 11 1 734 667 (#9)
· Spacer 11 11 1 739 185 (#10)
2-Oil Spraying Nozzle 11 42 1 730 618 (X4) €7.70 / $11.26
3-Hex Bolt 11 11 1 735 525 M10X75 €0.50 / $0.73
4-Cover lid 11 11 1 717 939 D=36MM (X4) €1.24 / $1.81
5-Plug 11 11 1 268 539 D=12,0MM (X1) €0.41 / $0.6
6-Dowel 11 12 1 726 238 D=10,5MM (X2) €0.90 / $1.32
7-Dowel 11 11 1 743 118 D=14,5MM (X2) €0.94 / $1.37
8-Dowel 11 12 1 726 241 D=12,5MM (X2) €0.90 / $1.32
9-Fuel flow reducer 11 11 1 717 807 (X1) €0.50 / $0.73
Non-return valve 11 11 1 734 667 (X1) €5.75 / $8.41
10-Spacer 11 11 1 739 185 (X1) €1.80 / $2.63
1-Connector 11 53 1 714 738 (X1) €8.40 / $12.28
2-O-ring 11 53 1 709 157 32X5 (X1) €1.19 / $1.74
3-Hex Bolt with washer 07 11 9 915 190 M6X20-Z1 non disponible (X1)
4-Gasket ring 07 11 9 963 130 A12X15,5-AL (X1) €0.03 / $0.04
07 11 9 963 200 A14X18-AL (X1) €0.22 / $0.32
5-Screw plug 07 11 9 919 225 AM12X1,5 (X1) €0.36 / $0.53
07 11 9 919 228 AM14X1,5 (X1) €0.36 / $0.53
6-Covering plate 11 14 1 734 019 (X1) €6.20 / $9.06
7-Gasket Steel 11 14 1 432 240 (X1) €1.82 / $2.66
8-Set of covers 11 14 1 438 715 (X1) €46.20 / $67.54
9-Hex Bolt with washer 07 11 9 913 110 M6X25-Z1 non disponible
Peut être remplacé par 07 11 9 905 400 M6X25-ZNNIV SI Chrome-free CR(VI) (X4) €0.28 / $0.41 et 07 11 9 915 046 M6X25-Z3 (X4) €0.22 / $0.32
10-Shaft seal 11 14 2 249 533 90X110X12 (X1) €30.60 / $44.73
11-Hex Bolt with washer 11 14 1 743 313 M8X25-Z1 €0.44 / $0.64
12-Dowel 11 12 1 726 238 D=10,5MM (X2) €0.90 / $1.32
13- ???
14-Blind plug 11 11 1 714 541 (X1) €1.05 / $1.53
15- ???
16- ???
17-Gasket Set Engine Block Asbesto Free 11 11 1 727 595 Set (X1) €97.80 / $142.97
1-Lower timing case 11 14 1 727 191 (X1) €170.00 / $247.66
2-Dowel 11 12 1 726 242 D=8,5MM (X2) €0.61 / $0.89
3-Gasket Asbestos Free 11 14 1 734 422 (X1) €9.95 / $14.5
4-Hex Bolt with washer 07 11 9 902 176 M8X60-Z1-ZNS (X2) €1.59 / $2.32
5-Fillister head screw 07 11 9 920 078 M8X20-Z1-8.8-ZN (X3) €0.36 / $0.52
6-Hex Bolt with washer 07 11 9 913 339 M6X50-Z1-ZN (X1)=50 pcs €0.12 / $0.17
7-Hex Bolt with washer 07 11 9 901 943 M6X30-Z1-ZNS non disponible (X2)
8-Hex Bolt with washer 07 11 9 915 190 M6X20-Z1 non disponible (X4)
9-Hex Bolt with washer 07 11 9 900 497 M10X25-8.8-ZNS (X1) €0.83 / $1.21
10-Profile-gasket 11 14 1 247 849 (X1) €4.94 / $7.2
11-Pulse generator 12 14 1 721 968 (X1) €100.00 / $145.68
12-Fillister head with washer 07 11 9 920 067 M6X16-Z1 (X2) €35.00 / $50.99
13-Bracket 12 14 1 727 766 (X1) €0.69 / $1.01
14-Guide 12 14 1 721 670 (X1) €5.65 / $8.23
1-Timing case cover, top 11 14 1 727 174 (X1) €51.00 / $74.2
2-Timing case cover, bottom 11 14 1 439 646 (X1) €83.50 / $121.48
3-Shaft seal 11 14 1 439 570 44X60X10 (X1) €14.90 / $21.68
4-Profile-gasket 11 14 1 247 837 (X1) €4.27 / $6.21
5-Hex Bolt with washer 07 11 9 901 973 M6X35-Z1-ZNS non disponible
6-Trigger contact 12 14 1 721 861 (X1) €70.10 / $101.99
7-O-ring 12 14 1 727 220 18X2 (X1) €0.37 / $0.54
8-Fillister head with washer 07 11 9 920 067 M6X16-Z1 (X2) €35.00 / $50.92
9-Hex Bolt with washer 07 11 9 901 137 (X1) M8X30-Z1-ZNS €0.57 / $0.83
ou 07 11 9 905 532 M8X30-ZNNIV SI Chrome-free CR(VI) (X1) €0.57 / $0.83
10-Hex Bolt with washer 07 11 9 901 787 M6X20-Z1-ZNS (X4) €0.16 / $0.23
11-Hex Bolt with washer 07 11 9 901 943 M6X30-Z1-ZNS non disponible
12-Hex Bolt with washer 07 11 9 901 675 11 M8X80-Z1 non disponible
peut être remplacé par 07 11 9 906 270 M8X80-U1-8.8 (X2) €182.00 / $264.79
13-Guide 12 14 1 727 221 (X1) €1.03 / $1.5
14-Bracket 12 14 1 727 777 (X1) €0.38 / $0.55
15-Gasket set chain case asbestofree 11 14 1 721 802 (X1) €8.50 / $12.37
16-Gasket set chain case asbestofree 11 14 1 721 919 (X1) €5.45 / $7.93
1-Oil pan upper part 11 13 1 715 120 (X1) €183.50 / $267.4
2-Stud bolt 07 12 9 908 133 M8X40-ZN (X1) €0.13 / $0.19
3-Cover 11 13 1 717 720 (X1) €2.65 / $3.86
4-Gasket Asbestos Free 11 13 1 739 592 (X1) €11.90 / $17.34
5-Hex Bolt with washer 11 13 1 247 070 M6X60 (X2) €0.30 / $0.44
6-Hex Bolt with washer 11 13 1 247 069 M6X18 €0.24 / $0.35
7-Oil pan 11 13 1 715 266 Without Levelling switch (X1) €90.50 / $131.88
8-Screw plug 11 13 1 273 093 M12X1,5 (X1) €1.85 / $2.7
9-Gasket ring 07 11 9 963 151 A12X17-CU (X1) €33.00 / $48.09
10-Gasket Asbestos Free 11 13 1 709 815 (X1) €9.00 / $13.11
11-Guide tube 11 43 1 717 942 L=484MM (X1) €17.10 / $24.92
12-O-ring 11 43 1 287 541 14,5X3 (X1) €0.53 / $0.77
13-Hex Bolt with washer 07 11 9 915 123 M6X16-Z3 (X1) €0.15 / $0.22
14-Dipstick 11 43 1 734 000 (X1) €8.55 / $12.46
15-O-ring 11 43 1 715 558 9X2,0 (X2) €0.51 / $0.74
Cylinder head
1-Cylinder Head With Bearing Ledges 11 12 1 739 913 €1445.00 / $2105.65
Seulement avec :
· Screw plug 07 11 9 904 550 (#16)
· Screw plug 07 11 9 919 113
· Gasket ring 07 11 9 963 130 (#15)
2-Bearing Ledge Intake 11 12 1 739 984 (X1) €242.00 / $352.64
Bearing Ledge Exhaust 11 12 1 739 985 (X1) €242.00 / $352.64
3-Dowel 11 12 1 713 264 D=9,5MM (X6) €1.75 / $2.55
4-Hex nut with plate 07 12 9 902 630 AM7 non disponible
5-Valve Guide 11 12 1 735 534 non disponible See Service Information SI 843 11/02/88
6-Dowel 11 12 1 713 264 D=9,5MM (X6) €1.75 / $2.55
7-Stud bolt 11 12 1 717 716 M7X98 €2.79 / $4.07
8-Stud bolt 07 12 9 908 125 M7X30 (X1) €57.00 / $83.06 (?? cf 9)
9-Stud bolt 07 12 9 908 199 M7X45 €0.38 / $0.55
10-Stud bolt 07 12 9 908 122 M7X55 (X5) €0.14 / $0.2
11-Screw plug 07 11 9 919 025 M20X1,5 (X1) non disponible
12-Screw plug 07 11 9 919 031 M24X1,5 (X1) €1.59 / $2.32
13-Valve Seat Ring Intake 11 12 1 435 920 34,5MM(+0,4) (X8) €9.00 / $13.11
14-Valve Seat Ring Exhaust 11 12 1 721 153 32,00MM(+0,4) €9.00 / $13.11
11 12 1 435 923 32,00MM(+0,4) (X8) €7.50 / $10.93
15-Gasket ring 07 11 9 963 130 A12X15,5-AL (X2) €0.03 / $0.04
16-Screw plug 07 11 9 910 368 M12X1,5X12 non disponible
Peut être remplacé par 07 11 9 904 550 M12X1,5X12 Chrome-free CR(VI) (X1) €3.71 / $5.41
1-Cylinder Head Gasket Asbestos-Free 11 12 1 721 546 1,74MM (X1) €53.70 / $79.01
11 12 1 721 550 2,04MM(+0,3) (X1) €65.70 / $96.66
2-Set Bolt Cylinder Head 11 12 1 721 939 TORX (X1) €17.10 / $25.16
3-Flat Washer 11 12 7 550 856 €0.32 / $0.47
4-Bracket 11 61 1 721 762 (X1) €6.55 / $9.64
5-Hex Bolt with washer 07 11 9 915 093 M8X20-Z1 (X2) €0.22 / $0.32
6-Remote thermometre sending unit 12 62 1 710 512 1-POL (X1) €14.80 / $21.78
7-Gasket ring 07 11 9 963 200 A14X18-AL (X1) €0.22 / $0.32
8-Temperature sensor 13 62 1 709 966 M12X1,5 (X1) €21.60 / $31.78
9-Gasket ring 07 11 9 963 130 A12X15,5-AL (X2) €0.03 / $0.04
10-Gasket set cylinder head asbestos free 11 12 9 063 333 Set (X1) €209.00 / $307.5
1-Cylinder head cover 11 12 1 721 198 (X1) €306.00 / $450.22
2-Cover lid 11 12 1 743 294 (X1) €4.21 / $6.19
11 12 7 509 328 (X1) €3.82 / $5.62
3-Profile-gasket 11 12 1 721 876 (X1) €19.20 / $28.25
4-Profile-gasket 11 12 1 721 476 (X3) €1.50 / $2.21
5-Profile-gasket 11 12 1 721 475 (X1) €1.74 / $2.56
6-Collar screw 11 12 1 721 883 M6X27,5 (X2) €1.33 / $1.96
7-Collar screw 11 12 1 721 877 M6X42,5 non disponible
Peut être remplacé par 11 12 7 568 809 M6X42,5 €1.68 / $2.47
8-Flat Washer 11 12 1 721 896 €0.74 / $1.09
9-Rubber seal 11 12 1 721 879 €0.54 / $0.79
10-Vent hose 11 15 1 717 858 (X1) €8.55 / $12.58
11-Connector 11 15 1 727 393 (X1) €1.39 / $2.05
Crankshaft drive
1-Vibration damper 11 23 1 721 169 (X1) €360.00 / $529.67
2-Pulley 11 23 1 721 204 (X1) €68.90 / $101.37
For vehicles with:
Power steering = Yes
Air conditioning = Yes
3-Hex Bolt with washer 07 11 9 900 268 M8X16-Z1 (X6) €0.23 / $0.34
4-Hex Bolt 11 21 1 721 100 M16X1,5X120 (X1) €3.78 / $5.56
5-Flat Washer 11 23 1 709 977 (X1) €3.78 / $5.56
6-Hub 11 21 1 721 099 (X1) €29.40 / $43.26
7-Pin 11 23 1 263 911 (X1) €0.51 / $0.75
8-Sprocket 11 21 1 247 338 (X1) €34.10 / $50.17
9-Woodruff key 07 11 9 951 480 5X6,5 (X1) €57.00 / $83.86
10-Fan belt 11 23 1 721 408 10X1025 SRC (X1) €9.40 / $13.83
1-At-crankshaft with bearing shells 11 21 1 721 816 (X1) €900.00 / $1324.17
Crankshaft with bearing shells 11 21 1 721 817 (X1) €930.00 / $1368.31
2-Bearing shell yellow 11 21 1 706 847 60,00MM(0) (X4) €8.10 / $11.92
Bearing shell green 11 21 1 706 848 60,00MM(0) (X4) €8.10 / $11.92
Bearing shell white 11 21 1 706 849 60,00MM(0) (X4) €8.10 / $11.92
Bearing shell yellow 11 21 1 706 850 59,75MM(+0,25) (X4) €10.50 / $15.45
Bearing shell green 11 21 1 706 851 59,75MM(+0,25) (X4) €10.40 / $15.3
Bearing shell white 11 21 1 706 852 59,75MM(+0,25) (X4) €10.40 / $15.3
Bearing shell yellow 11 21 1 706 864 59,50MM(+0,50) (X4) €10.40 / $15.3
Bearing shell green 11 21 1 706 865 59,50MM(+0,50) (X4) €10.40 / $15.3
Bearing shell white 11 21 1 706 866 59,50MM(+0,50) (X4) €10.40 / $15.3
3-Guide-bearing shell yellow 11 21 1 706 829 60,00MM(0) (X1) €13.60 / $20.01
Guide-bearing shell green 11 21 1 706 830 60,00MM(0) (X1) €13.60 / $20.0
Guide-bearing shell white 11 21 1 706 831 60,00MM(0) (X1) €13.60 / $20.01
Guide-bearing shell yellow 11 21 1 706 832 59,75MM(+0,25) (X1) €18.90 / $27.81
Guide-bearing shell green 11 21 1 706 833 59,75MM(+0,25) (X1) €18.90 / $27.81
Guide-bearing shell white 11 21 1 706 834 59,75MM(+0,25) (X1) €18.90 / $27.81
Guide-bearing shell yellow 11 21 1 706 855 59,50MM(+0,50) (X1) €21.40 / $31.49
Guide-bearing shell green 11 21 1 706 856 59,50MM(+0,50) (X1) €21.40 / $31.49
Guide-bearing shell white 11 21 1 706 857 59,50MM(+0,50) (X1) €21.40 / $31.49
4-Bearing shell yellow 11 21 1 717 526 60,00MM(0) (X5) €8.10 / $11.92
Bearing shell green 11 21 1 717 527 60,00MM(0) (X5) €8.10 / $11.92
Bearing shell white 11 21 1 717 528 60,00MM(0) (X5) €8.10 / $11.92
Bearing shell yellow 11 21 1 717 779 59,75MM(+0,25) (X5) €10.50 / $15.45
Bearing shell green 11 21 1 717 780 59,75MM(+0,25) (X5) €10.40 / $15.3
Bearing shell white 11 21 1 717 781 59,75MM(+0,25) (X5) €10.40 / $15.3
Bearing shell yellow 11 21 1 717 782 59,50MM(+0,50) (X5) €10.40 / $15.3
Bearing shell green 11 21 1 717 783 59,50MM(+0,50) (X5) €10.40 / $15.3
Bearing shell white 11 21 1 717 784 59,50MM(+0,50) (X5) €10.40 / $15.3
5-Bearing shell, blue 11 24 1 284 850 45,00MM(0) (X4) €8.55 / $12.58
11 24 1 284 852 44,75MM(+0,25) (X4) €11.30 / $16.63
11 24 1 284 854 44,50MM(+0,50) (X4) €11.30 / $16.63
6-Bearing shell, red 11 24 1 284 849 45,00MM(0) (X4) €9.15 / $13.46
11 24 1 284 851 44,75MM(+0,25) (X4) €8.40 / $12.36
11 24 1 284 853 44,50MM(+0,50) (X4) €8.40 / $12.36
1-AT-Set split conrod 11 24 1 437 617 (X1) €110.00 / $161.85
2-Connecting rod bush 11 24 1 278 209 (X4) €4.40 / $6.47
3-Dowel 11 24 1 280 833 Not suitable for two-part conrod (X8) €0.60 / $0.88
4-Connecting rod bolt 11 24 1 744 319 L=47MM non disponible
11 24 7 589 671 M9X47MM (X8) €1.85 / $2.72
11 24 1 713 342 L=53MM Not suitable for two-part conrod (X8) €2.91 / $4.28
1-Ks piston
11 25 1 721 446 83,980MM("0") (X4) €129.50 / $190.55
11 25 1 721 447 84,060MM("00") (X4) €129.50 / $190.55
11 25 1 721 448 84,230MM(+0,25) (X4) €129.50 / $190.55
11 25 1 721 449 84,480MM(+0,50) (X4) €129.50 / $190.55
3-Snap ring 07 11 9 934 460 C22X1,5 (X8) €0.15 / $0.22
4-Repair kit piston rings
11 25 1 727 461 84,000MM(0) (X4) €29.00 / $42.67
11 25 1 727 462 84,080MM(00) (X4) €28.60 / $42.08
11 25 1 727 463 84,250MM(+0,25) (X4) €28.60 / $42.08
11 25 1 727 464 84,500MM(+0,50) (X4) €28.60 / $42.08
1-Twin Mass Flywheel 21 21 1 223 550 (X1) 12.250kg €489.38 / $720.95
2-Dowel pin 11 22 1 709 069 10X23 Not suitable for Twin Mass Flywheel ?? (X3) €2.70 / $3.98
3-Dowel 11 11 1 743 118 D=14,5MM (X1) €0.94 / $1.38
4-Collar screw 11 22 1 717 841 M12X1,5X25 (X8) €1.17 / $1.72
Hex Bolt 11 22 2 243 051 M12X1,5X50 Only applies to Twin mass flywheel (X8) €1.33 / $1.96
5-Grooved ball bearing 11 21 1 709 681 12X32X10 (X1) €7.70 / $11.34
1-Timing chain 11 31 1 247 160 (X1) €70.70 / $104.16
2-Sprocket 11 21 1 247 338 (X1) €34.10 / $50.24
3-Woodruff key 07 11 9 951 480 5X6,5 (X1) €57.00 / $83.97
4-Sprocket 11 31 1 721 887 (X2) €34.20 / $50.38
5-Hex Bolt 11 31 1 727 306 M7X20 (X8) €0.22 / $0.32
6-Guide rail 11 31 1 247 470
· Fillister head screw 07 11 9 919 629 (#9) (X1) €30.90 / $45.52
7-Guide 11 31 1 721 419 (X1) €30.20 / $44.49
8-Fillister head screw 07 11 9 919 824 M6X35-Z1 Non disponible (X7) 0.009 kg / 0.02 lb
9-Fillister head screw 07 11 9 919 629 M6X45
1=50 pcs
Only applies to
· Guide rail 11 31 1 247 470 (#6)
· Guide rail 11 31 1 734 474
1 0.012 kg / 0.026 lb €0.27 / $0.4
07 11 9 919 936 M6X40
Only applies to
· Guide rail 11 31 1 727 148 (X1) €0.13 / $0.19
10-Flat Washer 11 31 1 727 496 non disponible
Only applies to
1 0.001 kg / 0.002 lb
11-Deflection wheel 11 31 1 727 569 (X1) €86.60 / $127.58
12-Fillister head screw 07 11 9 919 941 M8X40 (X1) €0.13 / $0.19
13-Flat Washer 07 11 9 900 052 A8,4 (X1) €0.05 / $0.07
14-Chain tensioner 11 31 1 727 342 (X1) €51.00 / $75.13
15-Bearing bolt 11 31 1 721 322 (X1) €12.20 / $17.97
16-Circlip 07 11 9 932 863 8,0 (X1) €0.05 / $0.07
17-Chain tensioner 11 31 1 743 187 (X1) €40.40 / $59.52
18-Gasket ring 07 11 9 963 355 A22X27-AL (X1) €0.15 / $0.22
19-Screw plug 11 31 1 721 579 (X1) €1.57 / $2.31
20-Slide rail 11 31 1 721 641 (X1) €9.25 / $13.63
1-Inlet camshaft 11 31 1 727 137 (X1) €371.00 / $546.56
Outlet camshaft 11 31 1 727 138 (X1) €397.00 / $584.86
2-Intake valve 11 34 1 722 908 33,0/6,97MM (X8) €21.20 / $31.23
Intake valve w.oversize va.system +0, 1MM 11 34 1 726 058
33,0/7,07MM Valve head thickness: +0, 2MM (X8) €26.50 / $39.04
3-Exhaust valve 11 34 1 727 151 30,5/6,96MM €37.00 / $54.51
4-Repair kit valve seal ring 11 34 9 059 171 (X2) €17.70 / $26.08
5-Lower spring pocket 11 34 1 726 969 €2.17 / $3.2
6-Lower spring pocket 11 34 1 722 544 €2.17 / $3.2
7-Valve spring 11 34 1 727 768 D=30,0MM €4.17 / $6.14
8-Valve spring 11 34 1 727 769 D=20,9MM €4.17 / $6.14
9-Upper spring plate 11 34 1 722 822 €2.17 / $3.2
10-Valve collet 11 34 1 307 136 €0.63 / $0.93
11-Hydraulic valve lifter 11 32 1 734 341 €18.50 / $27.25
