dunoyer21
DOC technique de l'evo 1 a 9
Evolution 1
Introduced Oct-92
Chassis Code CD9A-SNGF
Engine
Engine Type 4G63 in-line 4-cylinder, 16-valve DOHC, turbo with intercooler and intercooler water spray 4G63 in-line 4-cylinder, 16-valve DOHC, turbo with intercooler and intercooler water spray
Fuel System ECI-II multi-point fuel injection
Bore/Stroke 85.0/88.0mm
Compression 8.5:1
Max Power (bhp/rpm) 250/6,000
Max Torque
(lb ft/rpm) 228/3,000
Emission Control Catalytic converter
Max Speed 112mph limited
Fuel Type Super unleaded
Fuel Tank 50litre
Suspension and Steering
Front Axle MacPherson Strut
Rear Axle Multi-link with Pillowball Mountings
Front Brakes Ventilated Disc with 2-Pot Calipers with ABS
Rear Brakes Solid Disc with Single Pot Calipers
Steering Power Assisted, with Rack and Pinion
Tyres 195/55R15
Wheels 15x6.5j Alloy (15x7j Steel)
Driveline
Type Full-time 4WD with Centre Viscous Coupling Unit
Clutch Single Dry-Plate with Diaphragm Spring
Transmission Type 5-Speed Manual
1st 2.571
2nd 1.600
3rd 1.160
4th 0.862
5th 0.617
6th n/a
Reverse 3.166
Final Ratio 5.433
Dimensions and Weight
Length 4,310mm
Width 1,695mm
Height 1,395mm
Wheelbase 2,500mm
Front Track 1,450mm
Rear Track 1,460mm
Ground Clearance 150mm
Weight 1,240kg (1,170kg)
Colours
Carlton Red
Grace Silver Metallic
Pyreness Black Pearl
Saint Amour Green Metallic
Scotia White (Scotia White)
Evolution 2
Introduced Jan-94 Jan-94
Chassis Code CE9A-SNGF (CE9A-SNDF)
Engine
Displacement 1,997cc
Compression 8.5:1
Max Power (bhp/rpm) 260/6,000
Max Torque
Fuel Tank 50litre
Front Axle MacPherson Strut and forged lower arms
Tyres 205/60R15
Driveline
1st 2.750
2nd 1.684
3rd 1.160
4th 0.862
5th 0.617
6th n/a
Reverse 3.166
Final Ratio 5.433
Length 4,310mm
Width 1,695mm
Height 1,420mm
Wheelbase 2,510mm
Front Track 1,465mm
Rear Track 1,470mm
Ground Clearance 170mm
Weight 1,250kg (1,180kg)
Colours
Monaco Red
Moonlight Blue Pearl
Queen's Silver Pearl
Evolution 3
Introduced Aug-95 Aug-95
Engine
Engine Type 4G63 in-line 4-cylinder, 16-valve DOHC, turbo with intercooler and twin-jet intercooler water spray
Compression 8.8:1
Max Power (bhp/rpm) 270/6,250
Max Torque
Fuel Tank 50litre
Tyres 205/60R15
Driveline
1st 2.750
2nd 1.684
3rd 1.160
4th 0.862
5th 0.617
6th n/a
Reverse 3.166
Final Ratio 5.358
Length 4,310mm
Width 1,695mm
Height 1,420mm
Wheelbase 2,510mm
Front Track 1,465mm
Rear Track 1,470mm
Ground Clearance 175mm
Weight 1,260kg (1,190kg)
Colours
Dandelion Yellow
Monaco Red
Mais l'evo 1 et 2 aurait comme qui dirait un air de ressemblance avec la subaru GT mal tunnée pour la 2 lol
Beau travail de rcherche ;-)
EVO IV
Start of Production: August 1996
Number Produced: 9000
Length [mm]: 4330
Height [mm]: 1415
Width [mm]: 1690
GSR Weight [kg]: 1350
RS Weight [kg]: 1260
Chassis Code: CN9A
Engine Size: 1997.5
Bore and stroke: 85.0 x 88.0
Compression Ratio: 8.8:1
Power [bhp]: 276
Torque [lb/ft]: 260
Injector Size [cc]: 510
0-60mph: 4.8 secs
0-100mph: 12.9 secs
Top Speed [mph]: 150
Fuel Consumption: 23
Fuel Tank capacity: 48 Litres
Transmission: 5 Speed manual
Active Yaw Control [AYC]: Yes
Active Center Dif [ACD]: No
Gear Ratio 1st [GSR/RS]: 2.750/2.750
Gear Ratio 2nd [GSR/RS]: 1.950/1.950
Gear Ratio 3rd [GSR/RS]: 1.407/1.407
Gear Ratio 4th [GSR/RS]: 1.031/1.031
Gear Ratio 5th [GSR/RS]: 0.761/0.761
Gear Ratio Rev [GSR/RS]: 3.416/3.416
Gear Ratio Final [GSR/RS]: 4.529/4.529
EVO V RS
Start of Production: Jan 1998
Number Produced: 6000
Length [mm]: 4350
Height [mm]: 1415
Width [mm]: 1770
GSR Weight [kg]: 1360
Chassis Code: CP9A
Engine Size: 1998.6
Power [bhp]: 276
Torque [lb/ft]: 275
Injector Size [cc]: 560
0-60mph: 4.8 secs
0-100mph: 12.9 secs
Top Speed [mph]: 155
Fuel Consumption: 24
Gear Ratio 1st [GSR/RS]: 2.928/2.785
Gear Ratio 3rd [GSR/RS]: 1.407/1.444
Gear Ratio 4th [GSR/RS]: 1.031/1.096
Gear Ratio 5th [GSR/RS]: 0.720/0.761
EVO VI RS2
Start of Production: Jan 1999
Number Produced: 7000
Length [mm]: 4350
Height [mm]: 1415
Width [mm]: 1770
Chassis Code: CP9A
Engine Size: 1998.6
Power [bhp]: 276
Torque [lb/ft]: 275
0-60mph: 4.8 secs
0-100mph: 12.9 secs
EVO VI TME
Start of Production: Jan 2000
Number Produced: 5000
Length [mm]: 4350
Height [mm]: 1415
Width [mm]: 1770
Chassis Code: CP9A
Engine Size: 1998.6
Power [bhp]: 276
Torque [lb/ft]: 275
0-60mph: 4.8 secs
0-100mph: 12.9 secs
EVO VII and EVO GT-A (JP)
Start of Production: March 2001
Number Produced: 10000
Length [mm]: 4455
Height [mm]: 1450
Width [mm]: 1770
GSR Weight [kg]: 1400
RS Weight [kg]: 1320
Chassis Code: CT9A
Engine Size: 1998.6
Power [bhp]: 276, 300 [FQ Model]
Torque [lb/ft]: 282, 300 [FQ Model]
0-60mph: 4.7 secs
0-100mph: 12.7 secs
Active Center Dif [ACD]: Yes
Gear Ratio 5th [GSR/RS]: 0.720/0.825
EVO VII GT-A
Start of Production: Jan 2002
Number Produced: 2000
Length [mm]: 4455
Height [mm]: 1450
Width [mm]: 1770
GSR Weight [kg]: 1480
RS Weight [kg]: N/A
Chassis Code: CT9A
Engine Size: 1998.6
Power [bhp]: 276
Torque [lb/ft]: 253
Injector Size [cc]: 550
0-60mph: 5.5 secs
0-100mph: 13.8 secs
Fuel Consumption: 25
Transmission: 6 Speed manual or auto
Gear Ratio 1st: 2.928
Gear Ratio 2nd: 1.950
Gear Ratio 3rd: 1.407
Gear Ratio 4th: 1.031
Gear Ratio 5th: 0.720
Gear Ratio Rev: 3.416
Gear Ratio Final: 4.529
EVO VIII
Start of Production: Jan 2003
Length [mm]: 4455
Height [mm]: 1450
Width [mm]: 1770
GSR Weight [kg]: 1380
RS Weight [kg]: 1300
Chassis Code: CT9A
Engine Size: 1998.6
Power [bhp]: 265, 276, 300, 330
[FQ Models]
Torque [lb/ft]: 289, 300, 305
[FQ Models]
0-60mph: 6,1, 5,5, 5,1 secs
0-100mph: 12.5 secs
Top Speed [mph]: 160
Fuel Tank capacity [GSR/RS]: 55/50 Litres
Transmission: 5 or 6 Speed manual
Gear Ratio 1st [GSR/RS]: 2.909/2.785
Gear Ratio 2nd [GSR/RS]: 1.944/1.950
Gear Ratio 3rd [GSR/RS]: 1.434/1.444
Gear Ratio 4th [GSR/RS]: 1.100/1.096
Gear Ratio 5th [GSR/RS]: 0.868/0.825
Gear Ratio 6th [GSR/RS]: 0.693/NA
Gear Ratio Final [GSR/RS]: 4.583/4.583
EVO VIII MR
Start of Production: Feb 2004
Number Produced: 3000
Length [mm]: 4455
Height [mm]: 1450
Width [mm]: 1770
RS Weight [kg]: 1340/1310*
Chassis Code: CT9A
Engine Size: 1998.6
Power [bhp]: 300, 320, 340, 400
[3 FQ Models]
Torque [lb/ft]: Between 300-320
0-60mph: 4.6 secs , 3,8(mr FQ 400)
0-100mph: 12.5 secs
EVO IX RS
Start of Production: Feb 2005
Length [mm]: 4490
Height [mm]: 1450
Width [mm]: 1770
GSR Weight [kg]: 1410
GT Weight [kg]: 1390
Chassis Code: CT9A
Engine Size: 1997
Power [bhp]: 276 [more lively to be over 300]
Torque [lb/ft]: 295 GSR / 300 RS/GT
0-60mph: 4.4 secs
0-100mph: Uknown
Top Speed [mph]: Unknown
Fuel Consumption: Unknown
Fuel Tank capacity [GSR/GT/RS]: 55/55/50 Litres
Gear Ratio 1st [GSR/GT+RS]: 2.909/2.785
Gear Ratio 2nd [GSR/GT+RS]: 1.944/1.950
Gear Ratio 3rd [GSR/GT+RS]: 1.434/1.444
Gear Ratio 4th [GSR/GT+RS]: 1.100/1.096
Gear Ratio 5th [GSR/GT+RS]: 0.868/0.761
Gear Ratio 6th [GSR/GT+RS]: 0.693/NA
Gear Ratio Rev [GSR/GT+RS]: 2.707/3.416
Gear Ratio Final [GSR/GT+RS]: 4.583/4.529
