YS-R 0 Posté(e) le 4 avril 2011 OBDI 93-95 H22a Layout A1->A25--B1->B15--Blank--D1->D21A2->A26--B2->B16--Blank--D2->D22Pin---Color---------Desc. A1----brn-----------Injector #1 A2----yel-----------Injector #4 A3----red1---------Injector #2 A4----grn/yel------VTEC Solenoid Valve A5----blu-----------Injector #3 A6----or/wht-------HO2S heater coil A7----grn/blk1-----PGM-FI Main Relay coil A8----grn/blk2-----Shorted to A7 A9----blk/blu-------IAC Valve A10 A11----red2--------EGR Control SolenoidA12----blu/red-----Condenser Fan RelayA13----blu/wht-----MILA14 A15----red/blu-----A/C Clutch RelayA16----wht/grn-----AlternatorA17----pink---------IAB Solenoid ValveA18----orn/red-----FAS (A/T) A19----wht----------Intake Control Solenoid ValveA20----red/grn-----EVAP Purge Control SolenoidA21----yel/grn1----ICMA22----yel/grn2----Shorted to A21A23----blk1---------GNDA24----blk2---------GNDA25----yel/blk------PGM-FI Main Relay (power)A26----blk/red------VTEC Pressure Switch (GND)B1----yel/blk--------PGM-FI Main Relay (power)B2----brn/blk-------GNDB3----orn1----------AFSA (A/T) B4----pnk-----------AFSB (A/T) B5----blu/blk--------To A/C SwitchB6B7----lt grn---------ATP PN Gear Posisiton (A/T) B8----red/grn-------PSP SwitchB9----blu/red-------Starter Cut RelayB10---orn2----------VSSB11---orn3----------CYPB12---wht-----------CYPB13---orn/blu-------TDCB14---wht/blu-------TDCB15---blu/grn-------CKPB16--blu/yel--------CKPD1----wht/yel-------BatteryD2----grn/wht1-----Brake SwitchD3----red/blu-------KSD4----brn/wht------SCSD5 D6----lt blu or lt grn-VTEC Pressure SwitchD7----lt grn/red----Data Link ConnectorD8 D9----wht/red------ALTD10---grn/blk------ELDD11--red/blk-------TP SensorD12---wht/blk------EGR Valve Lift SensorD13---yel/blu-------ECT SensorD14---wht----------HO2S SenseD15---red/yel------IAT SensorD16 D17---wht/blu------MAP SensorD18---lt grn/blk----VREF (A/T) D19---red/wht------EGR Valve Lift SensorD20---yel/wht------TP SensorD21---blu/wht------MAP SensorD22---grn/wht2----TP SensorOBDII H22a 96+Layout A1->A11----Blank--C1->C10---D1->D5A12->A24--Blank--C11->C22--D6->D12A25->A32--Blank--C23->C31--D13->D16 Pin---Color ---------Desc. A1----yel------------Injector #4 A2----blu------------Injector #3 A3----red------------Injector #2 A4----brn------------Injector #1 A5----orn/blu-------Secondary O2 heater A6----blk/wht-------HO2S heater A7----orn------------EGR Control Solenoid Valve A8----grn/yel-------VTEC Solenoid Valve A9----brn/blk-------GND (dig) A10---blk------------GND (power)A11---yel/blk-------PGM-FI PowerA12---blk/blu-------Idle Air Control ValveA13 A14 A15---red/yel-------Evap Purge Control Solenoid ValveA16---grn/orn-------Fuel Pump RelayA17---pnk/blu-------A/C Clutch RelayA18---gry/red-------MILA19---wht/grn-------ALTA20---yel/grn--------ICMA21 A22---brn/blk--------GND (dig)A23---blk------------GND (power)A24---yel/blk--------PGM-FI PowerA25---wht-----------Intake Control Solenoid ValveA26---red/blu-------IAB Control Solenoid ValveA27---grn-----------Radiator Fan RelayA28---grn/wht------EVAP Bypass Solenoid ValveA29---orn/grn------Evap control cansiter vent shut valveA30 A31- A32- C1---lt grn/blk------Ref. Voltage for ATTS or TCM (not used)C2---blu------------CKP DetectC3---grn------------TDCP DetectC4---yel------------CKP DetectC5---blu/orn-------A/C Switch Signal InputC6---blu/red-------Starter Switch InputC7---red/wht-------SCSC8---lt grn ---------K Line (scan tool)C9-- -C10---wht/yel------ECM Backup PowerC11-- -C12---wht----------CKP GNDC13---red----------TDC M SideC14---blk----------CYP M SideC15---blu/blk------VTEC Pressure SwitchC16---grn----------P/S Pressure SwitchC17---wht/grn-----ALT Detect signalC18---blu/wht------VSS SignalC19 -C20 - -C21 - -C22---brn/yel------IMO Immobilizer Code SignalC23- -C24 - -C25 - -C26 - -C27 - -C28 - -C29 - -C30 - -C31 - -D1----red/blk----------TPS DetectD2----red/wht---------ECT Engine Coolant Temp. DetectD3----red/grn---------MAP DetectD4----yel/red----------Vcc1 (Power for MAP)D5----wht/blk----------BKSW Brake Switch DetectD6----red/blu----------KS (Knock Sensor Detect)D7----wht--------------HO2S DetectD8----red/yel----------IAT Intake Air Temp DetectD9----wht/blk----------EGR Valve Lift SensorD10---yel/blu----------Vcc2 (Provides Sensor Voltage)D11---grn/blk----------SG2 (Sensor Ground)D12---grn/wht---------SG1 (Sensor Ground)D13- -D14---wht/red---------SHO2S (Secondary O2 Sensor Detect)D15---wht/blu---------PTANK (Detects fuel tank pressure signal)D16---grn/red---------EL (Detects ELD Signal)Note: some of the pins listed for OBDII don't apply to te 96 and were only added in 97 but the layout is the same. Partager ce message Lien à poster Partager sur d’autres sites
YS-R 0 Posté(e) le 4 avril 2011 pour l'instant les infos sont des infos base ,sur tout et rien à la fois,on ne sais pas si on y arrivera,mais chaque chemin commence par un pas....... Partager ce message Lien à poster Partager sur d’autres sites
YS-R 0 Posté(e) le 4 avril 2011 bon voilà buzz apres qq heures de recherche ,j'ai toute la doc sur l'ATTS.maintenant,réglages,fonctionnent,composant.l'ATTS à sont propre unité de controle ,mais a besoins de 2 informations fournit par l'ECU qui est le couple,et la vitesse des roues,alors il suffirai de savoir quel fils est connecté à l'écu et il serait possible d'installer un boitié chipper . Partager ce message Lien à poster Partager sur d’autres sites
YS-R 0 Posté(e) le 4 avril 2011 BUZZ si ça t'interresse je peux t'envoyer les dossier sur l'ATTS en fichier ZIP par mail. Partager ce message Lien à poster Partager sur d’autres sites
Buzz29 0 Posté(e) le 5 avril 2011 Je pense que je l'ais déja Celui la?Je ne pense pas que tu en ais trouvé un autre!En tout cas merci a toi de te lancer la dedans, même si tu aime sa, plusieurs se sont cassé les dents la dessus!Mais moi je crois en toi Partager ce message Lien à poster Partager sur d’autres sites
Buzz29 0 Posté(e) le 5 avril 2011 YS-R a écrit:l'ATTS à sont propre unité de controle ,mais a besoins de 2 informations fournit par l'ECU qui est le couple,et la vitesse des roues,alors il suffirai de savoir quel fils est connecté à l'écu et il serait possible d'installer un boitié chipper .Sa serait si facile que ca? sa m'étonne!Je vais éssayer de retrouver les recherches que l'ont avait fait sur le HPC, mais sa remonte a un bout de temps... Partager ce message Lien à poster Partager sur d’autres sites
YS-R 0 Posté(e) le 5 avril 2011 merci pour l'encouragement BUZZ!!!!Mais en fait c'est la même documentation!!!!!!!pas grave.Si tu pouvais prendre une photo de ton boitier ECU, des photos précises de l'interieur du boitier,et la photo de l'étiquette qui se trouve sur le coté de l'ECU pour voir le model que c'est.C'est bien de l'OBD2-A n'est ce pas????Et si tu pouvais trouver le schéma electrique de la voiture ce serai le top, je pourrai voir de façon plus claire les connectiques entre l'ECU, et l'ATTS controle unit.Mais, je pense vraiment que c'est possible vue les 2 celluses sont dissocier en 2 boitier. Partager ce message Lien à poster Partager sur d’autres sites
Buzz29 0 Posté(e) le 5 avril 2011 Ben écoute, j'ai un ECU en rab, que j'avais récuperer avec mon moteur donc sa va ètre simple je te confirme c'est bien de l'OBD2 A!Sinon je te met un lien ou tu pourra télécharger le wiring diagram complet:http://carpdf.net/honda-prelude-97-wiring-diagram.htmAvec sa t'as déja de quoi te prendre la tête Partager ce message Lien à poster Partager sur d’autres sites
YS-R 0 Posté(e) le 6 avril 2011 OK c'est partie mon kiki!!!!! Partager ce message Lien à poster Partager sur d’autres sites
Buzz29 0 Posté(e) le 6 avril 2011 Tiens, voila pour ton kiki à gauche l'ECU moteur, à droite celui de l'ATTS.Le code de l'ECU Je précise que ce n'est pas l'ECU de ma voiture, mais un récuperé sur une Vtis! Je ne sais pas si il fonctionne toujours car il a pris la flotte Et par curiosité l'ECU de l'ATTS:Voila, avec sa tu va pouvoir te torturé l'esprit Partager ce message Lien à poster Partager sur d’autres sites
YS-R 0 Posté(e) le 7 avril 2011 veullier patientez la recherhce est en cour..... Partager ce message Lien à poster Partager sur d’autres sites
YS-R 0 Posté(e) le 7 avril 2011 t'es au top pour les photos je pouvais pas demander mieux. y a pas mieux pour bosser... Partager ce message Lien à poster Partager sur d’autres sites
YS-R 0 Posté(e) le 7 avril 2011 En rouge c'est le CMD (eprom) qui faut changer pour faire une cartographie sur le P5P, mais j'ai pas le niveau,ni l'eprom ,ni le graveur....En jaune c'est la prise de dataloggage....voilà le lien qui te montre comment on chippe ce processeur.... les connections des fils pour se repérer si il y a une dif entre un ECU chipper et le P5P sh ATTS .....Tu sais comment je peut mettre sur la page un fichier PDF j'ai le schéma electrique pour l'ATTS.je m'arréte là pour ce soir, bientot 4 heure du mat depuis minuit c'est pas mal quand même....demain j'aurai les idée plus claire pour voir sur le schéma si il y a une une différent pour les connection de l'ECU P5P et un P28. Partager ce message Lien à poster Partager sur d’autres sites
fab18 0 Posté(e) le 7 avril 2011 salut mon sushi!!!! comment qu'c'est??? Partager ce message Lien à poster Partager sur d’autres sites
YS-R 0 Posté(e) le 7 avril 2011 super mon bon baf,super !!!!et ton B18??? Partager ce message Lien à poster Partager sur d’autres sites
kevinou 0 Posté(e) le 8 avril 2011 ce Week end chacun son domaine !!! Partager ce message Lien à poster Partager sur d’autres sites
NarSkaL 0 Posté(e) le 8 avril 2011 T'es un ouf sushi Partager ce message Lien à poster Partager sur d’autres sites
YS-R 0 Posté(e) le 9 avril 2011 bon j'ai chercher, et donc.....en comparant les wiring diagram sur les preludes VTI-S 97, les civic 97/99 OBD2-a,les Del sol version ABD2-a,et civic 92/95 en OBD1,il y a que 2 connectique où se pose un probléme eventuelle.... Sur la photo ci dessus ce sonts des connctiques obd2-a pour une civic B16,j'ai marqué la différence entre la prelude vti-S.Les carrés rouge sont les connectiques existant sur la prelude,en noir les connectiques inutilisées par la par la prelude.en rouge:A7 =ESOL : (left side engine compt ) exhaust gasrecirculation controle solenoid valve.canister mod california 97/98.A28 =2WBS :evaporative emission by pass solenoid valve( california 97/98).A29 =VSV :retour du A7 ESOL.C20 =PFSW:evaporative emission purge flow switch(97 california).C22 =imocode :pour le code anti demarrage.C30 =FITX/SEAF:ATTS CONTROL UNIT (sh only)/ and transmission control module (AT only).C31 =FIRX/SEFA:ATTS CONTROL UNIT (sh only)/ and transmission control module (AT only).En encadré noir :C9 =fas inutilisé sur les models civic ECO/VTI 96/99 et del sol 97 VTI.C11 =CKFM capteur d'enclanchement de rapport.C19 =ATCHH inutilisé sur les models civic ECO/VTI 96/99 et del sol 97 VTI.C21 =BARO inutilisé (mais peut etre pression atmo) utilisé sur les PW0.C27 =AFSB seuleument sur les version boite auto indique le rapport choisis au levier de vitesse.C28 =AFSA seuleument sur les version boite auto indique le rapport choisis au tableau de bord. Partager ce message Lien à poster Partager sur d’autres sites
YS-R 0 Posté(e) le 9 avril 2011 on retiendra donc les connections nécessaire sont C30, et C31 ici avec une croix bleu,qui sont utilisées aussi pour la version auto de la prelude de cette époque ,donc il suffirai de se renseigner sur les personnes qui aurai chippé les preludes 2.2 VTI équipé en boite automatique pour voir les modifs qu'ils sont du faire.mais on rentre dans un paradoxe concernant pour les ECU chipper puisqu'on désoude 2 composant pour les passer en version boite manuel pour les versions qui étaient sur une boite auto.Ici entourer en bleu. Partager ce message Lien à poster Partager sur d’autres sites
YS-R 0 Posté(e) le 13 avril 2011 la solution pour buzz!!! comme je le disais le paradox d'une boite manuel avec une fonction signal comme les boites auto le P5P.Avec un ecu chipper où on enléve 2 composants pour pouvoir le passer en manuel si l'ECU est prevu au depart pour une boite auto. Ici entouré en bleu.Et j'ai trouvé une discution à ce sujet ,avec le lien ,mais sans photos:Bon, la solution "simple" (faisceau de conversion avec ECU OBD1 de boite auto, chippé avec reprog), je sais pas du tout si ça marche. Peut-être, puisque c'est un boitier spécifique qui gère la boite (régimes de changements de rapports entre autres). Si ça ne marche pas, j'ai déjà vu un truc fun sur pgmfi.org. C'était sur une Prelude VTI-S avec ATTS (différentiel électronique géré par l'ECU). Un changement d'ECU impliquait donc de perdre l'ATTS. Du coup les gars ont fait un faisceau de conversion pour faire fonctionner deux ECU : les mêmes signaux d'entrée, et l'ECU d'origine relié à l'ATTS, l'ECU modifié relié au moteur. Ça tournait bien et les photos du faisceau étaient amusantes. Malheureusement les photos ne sont plus hébergées... Si ça t'intéresse je peux retrouver le lien. le lien de la discution:http://www.japancar.fr/forum/viewtopic.php?printertopic=1&t=168072&postdays=0&postorder=asc&vote=viewresult Partager ce message Lien à poster Partager sur d’autres sites
bidourx 0 Posté(e) le 14 avril 2011 il est chaud le sushi Partager ce message Lien à poster Partager sur d’autres sites
kevinou 0 Posté(e) le 15 avril 2011 allez buzz au taff !!c'est pas breizh qui avait un ecu moteur chipper pour la EJ automatique ?? Partager ce message Lien à poster Partager sur d’autres sites
YS-R 0 Posté(e) le 16 avril 2011 Bon j'ai approfondi mes recherches,et même si le chippage est fesable,je te déconseille toutes modifications.L'ATTS est constitué d'un couplage multidisque de disques garnis,et de disques lisses comme en moto.Et le transfer de couple vers la droite ,ou vers la gauche améne à un débrayage des disques droit,ou gauche.Donc plus il y aura d'effort plus vite ils vont chauffer ,et finir par bruler.L'huile pour l'ATTS, je te conseille fortement de la changer dans les temps préconiser par le constructeur,et met la bonne huile.maitenant à toi de faire le choix. Partager ce message Lien à poster Partager sur d’autres sites
NarSkaL 0 Posté(e) le 16 avril 2011 Rien ne vaut un bon vieux torsen Vive ma future boite d'ATR Partager ce message Lien à poster Partager sur d’autres sites
