Invité Posté(e) le 14 janvier 2007 Zabuza a écrit:Fault Codes Explained This page explains what each of the PGM-Fi fault codes means, the implications on operation of the ECU when running under the fault condition, and comments on typical causes for the fault. To read how to obtain fault codes from your vehicle, please take a look here. 1 Oxygen Sensor "A" (Primary) Honda say Defective circuit or unplugged / defective sensor. Implications ECU will probably not run in closed loop operation. Comment With OBD-0 VTEC ECU's such as the PW0 and PR3 that run two primary oxygen sensors (one for each pair of cylinders) make sure you have the correct sensor in the correct manifold boss! 2 Oxygen Sensor "B" Honda say Defective circuit or unplugged / defective sensor. Implications To follow. Comment More details to follow. Secondary oxygen sensor's purpose is typically to monitor the performance of the catalytic converter. 3 MAP Sensor (Manifold absolute pressure) Honda say Defective circuit or unplugged / defective sensor. Implications To follow. Comment To follow, please see details for fault code 5. 4 CKP Sensor (Crankshaft position) Honda say Defective circuit or unplugged / defective sensor. Implications To follow. Comment To follow. 5 MAP Sensor (Manifold absolute pressure) Honda say Defective circuit or unplugged / defective sensor / incorrect pipework. Implications ECU will run TPS based routine. Comment The MAP sensor is the primary load input, and on failure the ECU will run some form of substitution based on the TPS input. Engine will run, although generally not idle and performance is severely impaired. Do not run the engine any longer than required to get the car to a repair shop. 6 ECT Sensor (Engine coolant temperature) Honda say Defective circuit or unplugged / defective sensor. Implications ECU will ignore the input if it is not within range, and substitute a fixed value. Comment Fixed value substituted when input is not in range varies depending on engine RPM - commonly 85°C during normal operation, although this is raised during cranking. 7 TP Sensor (Throttle position) Honda say Defective circuit or unplugged / defective sensor. Implications To follow. Comment Incorrect adjustment or failure of the TPS sensor or wiring issues will cause a number of problems, mainly idle related. Details of adjustment procedure to follow. 8 TDC Sensor (Top dead centre) Honda say Defective circuit or unplugged / defective sensor. Implications To follow. Comment To follow. 9 CYP Sensor (Cylinder position) Honda say Defective circuit or unplugged / defective sensor. Implications To follow. Comment To follow. 10 IAT Sensor (Intake air temperature) Honda say Defective circuit or unplugged / defective sensor. Implications ECU will ignore the input if it is not within range, and substitute a fixed value. Comment Details of fixed value used to follow. 11 IMA Sensor (Idle mixture adjust) Honda say Defective circuit or unplugged / defective sensor. Implications Probably substitution of fixed value if input is not within range. Comment Sometimes known as the CO Pot. This is fitted to OBD-0 ECU's in some vehicles that do run an lambda sensor. This only applies to some some markets, like the UK where fitting of a catalytic converter was not law until 1991. The input is simply a potentiometer that is used to trim the base fuelling - hence the name CO pot. 12 EGR Lift Sensor (Exhaust gas recirculation) Honda say Defective circuit or unplugged / defective sensor. Implications Unknown. Comment EGR is used for emission control. 13 BARO Pressure Sensor (Atmospheric pressure sensor) Honda say Defective circuit or unplugged / defective sensor. Implications ECU will ignore the input if it is not within range, and substitute a fixed value. Comment This sensor is commonly fitted with US and European ECU's, it is not normally found on JDM units. With OBD-0 ECU's this sensor is external to the ECU and on all later units (including OBD-0 VTEC ecu's such as the PW0) it is a small module fitted internally to the PCB. 14 IAC Valve (Idle Air Control) Honda say Defective circuit or unplugged / defective valve. Implications Unknown. Comment Only applies to vehicles equipped with an automatic transmission. 15 Ignition Output Signal Honda say Missing or defective ignition output signal. Implications To follow. Comment To follow. 16 Fuel Injector System Honda say Defective circuit or unplugged / defective sensor. Implications Unknown. Comment Problem with fuel injectors. 17 VSS (Vehicle Speed Sensor) Honda say Defective circuit or unplugged / defective sensor. Implications If engine is VTEC model, it will not be engaged. Comment Early 1990 VSS sensors as fitted to B series engined MK2 Integra's and MK2 CRX's are prone to failure - the design was modified and late 1991-onwards vehicles rarely get VSS problems. 18 Ignition Timing Honda say Unknown. Implications Unknown. Comment Not quite sure about this one! 19 Automatic Transmission Lock Up Control Solenoid Valve Honda say Defective circuit or unplugged / defective solenoid valve . Implications Unknown. Comment Only applies to vehicles equipped with an automatic transmission. 20 ELD (Electrical Load Detector) Honda say Defective circuit or unplugged / defective solenoid valve . Implications Unknown. Comment This is a solid-state hall effect current sensor, commonly mounted in the engine compartment's fuse box (normally located on top of a suspension turret) and it's purpose is to monitor current demand for precise emission control. 21 VTEC Solenoid Valve Honda say Defective circuit or unplugged / defective solenoid valve. Implications VTEC will not be engaged, no high cam lobes. Comment Solenoid, or "spool" valve that allows oil to flow into the VTEC mechanism. VTEC will obviously not operate and engine will feel breathless at higher RPM's. High RPM driving should be avoided as the engine will only be operating on the low speed lobes. 22 VTEC Oil Pressure Switch Honda say Defective circuit or unplugged / defective pressure switch. Implications VTEC will not be engaged, no high cam lobes. Comment This switch was only used on early VTEC engines - note it is not to be confused with the oil pressure switch. Commonly caused by idiots who don't check their oil level - so if it flashes up during hard cornering or braking then stop and immediately and check the dipstick! The VTEC mechanism is operated hydraulically from the engine's main oil supply and when it is first engaged causes a momentary fluctuation in oil pressure, and demand on the pump - if pressure available to the VTEC mechanism is not high enough, it will disable VTEC. 23 KS (Knock Sensor) Honda say Defective circuit or unplugged / defective pressure sensor. Implications To follow. Comment ECU will be unable to trim ignition timing to adapt for differing environmental conditions, and quality of fuel. 30 Automatic Transmission Signal "A" SEAF / SEFA / TMA or TMB Honda say Defective circuit or unplugged / defective sensor. Implications To follow. Comment To follow. 31 Automatic Transmission Signal "B" Honda say Defective circuit or unplugged / defective sensor. Implications To follow. Comment To follow. 41 Primary Oxygen Sensor - Heater Honda say Defective circuit or unplugged / defective sensor. Implications To follow. Comment To follow. 43 Fuel Supply System Honda say Defective circuit or unplugged / defective sensor. Implications To follow. Comment This is generally flagged when the engine is running either very rich, or lean due to a mechanical problem, or very bad tuning. Based on Lambda sensor input to some extent. Get a wideband AFR meter on the car - also check your injectors and fuel pressure. 43 Fuel Supply System Honda say Defective circuit or unplugged / defective sensor. Implications To follow. Comment This is generally flagged when the engine is running either very rich, or lean due to a mechanical problem, or very bad tuning. Based on Lambda sensor input to some extent. Get a wideband AFR meter on the car - also check your injectors and fuel pressure. 48 LAF Sensor (Lean Air Fuel) Honda say Defective circuit or unplugged / defective sensor. Implications To follow. Comment To follow. 54 CKF Sensor (Crankshaft Speed Fluctuation) Honda say Defective circuit or unplugged / defective sensor. Implications To follow. Comment This sensor is mounted behind the timing belt sprocket on the crank, and used to closely monitor the speed of the crank to detect a misfire etc. Only fitted to OBD-2 systems. 58 TDC Sensor 2 (Top Dead Centre) Honda say Defective circuit or unplugged / defective sensor. Implications To follow. Comment To follow. 61 Oxygen Sensor, Heated - Sensor 1 (Primary) Honda say High voltage, low voltage or slow response. Implications To follow. Comment To follow. 63 Oxygen Sensor, Heated - Sensor 2 (Secondary) Honda say High voltage, low voltage or slow response. Implications To follow. Comment To follow. 65 Oxygen Sensor Heater (Secondary) Honda say Defective circuit or unplugged / defective sensor. Implications To follow. Comment To follow. 67 Catalyst System Efficiency Below Threshold Honda say Malfunctioning or defective catalyst system. Implications To follow. Comment To follow. 70 Automatic Transmission Honda say Malfunction with the automatic transmission controls. Implications To follow. Comment To follow. 71 Cylinder 1 Missfire or a Random Missfire Honda say A condition is present that is creating a cylinder misfire. Implications To follow. Comment To follow. 72 Cylinder 2 Missfire or a Random Missfire Honda say A condition is present that is creating a cylinder misfire. Implications To follow. Comment To follow. 73 Cylinder 3 Missfire or a Random Missfire Honda say A condition is present that is creating a cylinder misfire. Implications To follow. Comment To follow. 74 Cylinder 4 Missfire or a Random Missfire Honda say A condition is present that is creating a cylinder misfire. Implications To follow. Comment To follow. 75 Cylinder 5 Missfire or a Random Missfire Honda say A condition is present that is creating a cylinder misfire. Implications To follow. Comment To follow. 76 Cylinder 6 Missfire or a Random Missfire Honda say A condition is present that is creating a cylinder misfire. Implications To follow. Comment To follow. 80 Exhaust Gas Recirculation Honda say Insufficient flow detected. Implications To follow. Comment To follow. 86 ECT Sensor (Engine Coolant Temperature) Honda say Insufficient flow detected. Implications To follow. Comment To follow. 90 Evaporative Emission Control System Honda say Leak detected in the fuel tank area. Implications To follow. Comment To follow. 91 Fuel Tank Pressure Sensor Honda say Low input. Implications To follow. Comment To follow. 92 Evaporative Emission Control System Honda say Insufficient purge flow. Implications To follow. Comment To follow Partager ce message Lien à poster Partager sur d’autres sites
Invité Posté(e) le 14 janvier 2007 Zabuza a écrit:Facile, toutes les donnes sont gerees par ton ECU (voir lexique hihi) qui les traite et qui vient jouer sur tous ces parametres quand tu conduis (aumentation de la quantite d essence en fonction de l air admis quand tu acceleres, du regime, position des AAC, de la temperature du liquide de refroidissement Ton ECU traite ces donnees, mais il lui arrivent parfois que certaines ne correpondent pas a ce qui doit recevoir (en fonction de la cartographie d injection) De ce fait ta voiture tourne moins bien Donc il sufffit de se connecter a une petite prise qu on appelle "prise diagnostic" et de faire une petite manip avec un fil de faire ou un trombone ( c est la methode de ceux qui ont pas envie d aller chez le concessionnaire pour claquer des sous) tu vas avoir, donc, des signaux courts et longs sur ton tableaux de bord il suffit de les compter 7 cours et 1 long te donnent un code 71 71 Cylinder 1 Missfire or a Random Missfire Honda say A condition is present that is creating a cylinder misfire. Implications To follow. Comment To follow. probleme d allumage sur le cylindre no 1 a verifier donc: bougie ou fil de bougie... Partager ce message Lien à poster Partager sur d’autres sites
Invité Posté(e) le 14 janvier 2007 bidoucrx a écrit:petite rectification :(du moin je parle pour la mienne ) le temoin (la LED) qui te donne le code ERROR est sur le dessu de l'ECU elle est rouge par contre normalement en cas de probleme ton voyant orange(hazar) s'allume aussi Partager ce message Lien à poster Partager sur d’autres sites
