Land Rover 0 Posté(e) le 27 mars 2010 Hyper 21 Engine 8 Port Pull Start environ 130$ SPEC:- CLAIMED HP 2.5 RPM 38,000 CARB TYPE SLIDE CRANK SG CONSTRUCTION ABC ENGINE SIZE .21 TYPE REAR EXHAUST :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::Hyper .21 8 Port Race with Boost environ 120$ SPEC: CLAIMED HP 2.7 RPM 38,000 CARB TYPE SLIDE CRANK SG CONSTRUCTION ABC ENGINE SIZE .21 TYPE REAR EXHAUST :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::SH Engines (#PT2008-XB) Pro Compet 1/8 Off Road Engine environ 200$ Spec: For: 1/8 Off-road cars 3 Needle Carb. Ceremic Pistion Cublic Capacity: 3.497cc Bore: 16.27mm Stroke: 16.75mm R.P.M: 38000rpm Power: 2.8hp :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::GO 21 7+2p Standard Race Engine environ 200$Contents 3.45cc Maximum Power 2.7hp R.P.M 39.000rpm Practical Range 6.000/44.000rpm Bore/Stroke 16.26mm/16.80mm Ports 7+2 Crankshaft 14mm SG Carburetor 8mm Glow Plug Type Standard Exhaust Type Rear ::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::NOVAROSSI Plus21-4 environ 300$ SPEC:Displacement: 3,5cc (.21)Maximum Power: 2,60 hp R.P.M: 32.000 R.P.M Practical Range: 6.000 ~ 38.000 R.P.M. Bore For Stroke: 16,26mm x 16,80mm Ports.: N. 4 Balls type: Steel Starting: Starterbox Crankshaft Type: TURBO SG - Tuned Exhaust Type: Rear :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::SH Engines (#PT2503) 25 Rear Exhaust Engine environ 230$Spec:For: 1/8 Off-road cars Cublic Capacity: 4.02cc Bore: 17.50mm Stroke: 16.75mm R.P.M: 33000rpm Power: 3.3hp :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::OS 21 VZB V-Spec w/ new Carb environ 300$SPEC:Stock Number: OSMG2068Displacement: .21 cu in (3.5 cc)Bore: 0.653 in (16.6 mm)Stroke: 0.629 in (16.0 mm)Practical rpm: 3,000-40,000Output: 2.5 hp @ 33,000 rpmWeight (w/o muffler): 12.7 oz (360 g)Includes: TP-3 glow plug, 8 mm and 9 mm carb restrictors, exhaust seal and dust cap ::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::O.S .25XZ pour environ 300$ SPEC:Displacement: 0.25 cu in (4.1 cc)Output: 3.1 hp @ 33,000 rpmBore: 0.689 in (17.5 mm)Stroke: 0.669 in (17 mm)Practical rpm: 4,000-39,000:::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::O.S .28XZ pour environ 300$ SPEC:Displacement: 0.284 cu in (4.65 cc)Bore: 0.728 in (18.5 mm)Stroke: 0.681 in (17.3 mm)Practical rpm: 4,000-38,000Power Output: 3.31 hp @ 32,000 rpm::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::SH Engines (#PT2802B-P3) 28 Pro Rear Exhaust environ 140$ Spec:Cubic capacity: 4.59 cc Bore: 18.50 mm Stroke: 17.00 mm R.P.M : 28,000 Power: 3.5bhp@28,000rpm Weight: 410 g w/o pullstart Dual ball bearing::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::HYPER 28 ENGINE - 3PORT W/O PULL STARTER environ 120$(J'ai pas rouver de spec...)Je prévois acheter un moteur pour un future buggys 1/8.... et parmi c'est chois le quel choisiriez vous ? .21 ?.25 ?.28 ?O.S ?GO emgine ?Ofna/Ho bao (Hyper) ?SH engine ?Novarossi ?J'élimine déjà les moteur de over 330$(sans TX et Ship) certaine marque et toutes les boutique en provenances des u.s.....ALORS DONNER VOTRE AVIS !!! Edit ajout de 2 moteur... Partager ce message Lien à poster Partager sur d’autres sites
cletus78 0 Posté(e) le 27 mars 2010 allo moi jai le deuxieme modele que ta montrer le hyper 21 8 port pro race edition avec la boost botle jai du enlever le systeme du boost car sa tirais pas pis ses des moteur dur a ajuster en maudit il garde pas leur setting Partager ce message Lien à poster Partager sur d’autres sites
Land Rover 0 Posté(e) le 27 mars 2010 merci pour ton opinion! j'en tien compte Partager ce message Lien à poster Partager sur d’autres sites
cletus78 0 Posté(e) le 27 mars 2010 si tu veut pas te tromper va sy avec le os vzb tu te tromperas pas beaucoup de monde cours avec se moteur facile a tuned et ses des moteur qui son tof . et pour un buggy reste dans les moteur .21 .25 ou .28 ses trop de torque pour ce que ta besoin dans un buggy Partager ce message Lien à poster Partager sur d’autres sites
