Sylvain-rcbsl 0 Posté(e) le 19 octobre 2005 Voici un autre truggy..... Le Kyosho Inferno ST-S...400$US street price ! Les specs... The exciting new Inferno ST ReadySet combines the value and convenience of a RTR with the performance and durability of the most successful nitro-powered racing machine in the history of RC racing. The Inferno ST isn't a just a buggy with truck wheels; it's a true truggy with a unique chassis and suspension that's designed and tested for competition. The new and very powerful GXR28 engine is standard in the Inferno ST. This engine is specially designed with specifications from racing engine experts at Kyosho for the best possible performance and reliability. A big-bore slide carb is standard equipment, which provides snappy throttle response and very linear throttle control. The engine also features an exclusive new pull-starter design that eliminates the one-way bearing. The starter engages with the crankshaft when the starter is used, but once the engine starts, the start completely disengages from the crankshaft, so you get the performance of a non-pullstart engine. The ST features an extended plate chassis with channeled edges for extra strength. It also features a longer wheelbase than a 1/8 buggy, but it's slightly shorter than other truggies. At 350mm, the wheelbase of the Inferno ST is long enough to provide excellent stability, but the wheelbase is slightly shorter than other truggies to provide superior steering response to get you through the corners faster than a long wheelbase machine. Extra long suspension arms give the ST massive suspension travel and excellent geometry. That means it can soak up the bumps and big air landings and it can still dive underneath the competition in the tight corners on the racetrack. The suspension is damped with composite shocks that feature threaded spring preload adjusters. The shocks have five lower mounting positions with seven upper positions for the rear shocks and 4 up front. There are caster, camber, toe, anti-squat, and many other adjustments that can be made to race tune the Inferno ST in a matter of seconds. SKU - 31351B Street Price - $399.99 Available - November '05 Equipped with a GX-28 engine with tuned pipe Engine features a pull start with no one-way bearing Long front arms for massive suspension travel Extended upper links for superior strength 19mm hex and 14mm hex (TMaxx size) Threaded shock bodies Specifications Length: 19.68 in. (500mm) Width: 16.34 in. (415mm) Height 5.9 in. (150mm) Wheelbase: 13.78 in. (350mm) Track Width: (F/R) 258mm - 261mm Tire Size: (F/R) 5.7 in. (145mm) dia. / 2.9 in. (73.5mm) width Gear ratio: 15.22:1 Total Weight: 121.7 oz. (3450g) Engine GX-28 Partager ce message Lien à poster Partager sur d’autres sites
charles-maxx 0 Posté(e) le 20 octobre 2005 NOT BAD! Partager ce message Lien à poster Partager sur d’autres sites
