djo88 0 Posté(e) le 2 janvier 2008 D13 Series Engines (1.3 Litre) [edit] D13B1 Found in: 1988-1991 Honda Civic DX (European Market) Displacement : 1343 cm³ Bore and Stroke : 75 mm X 76 mm Compression : 9.5:1 Power, Torque : n/s (Not stated in Owners Manual) Valvetrain : SOHC, 4 valves per cylinder Fuel Control : Single Carburetor [edit] D13B2 Found in: 1992-1995 Honda Civic DX (European Market) Displacement : 1343 cm³ Bore and Stroke : 75 mm X 76 mm Compression : 9:1 Power, Torque : 75 hp (56 kW) @ 4500 rpm Valvetrain : SOHC, 4 valves per cylinder Fuel Control : Single Carburetor [edit] D-SERIES [edit] D14A2 Found in: 1995-1996 Honda Civic MA8 (European Market) Displacement : 1396 cm³ Bore and Stroke : 75.0 mm X 79.0 mm Compression : 9.2:1 Torque, Power : 117 Nm @ 3800 rpm, 66 kW @ 4800 rpm Valvetrain : SOHC, 4 valves per cylinder Fuel Control : Multi-point fuel Injection, PGM-FI [edit] D15 Series Engines (1.5 Liters) [edit] D15A2 Found in: 1984-1987 Honda CRX DX 1984-1987 Honda Civic (JDM) Displacement : 1488 cm³ Bore and Stroke : 74 mm X 86.5 mm Compression : 9.6:1 Power : 76 hp (57 kW) @ 4500 rpm & 84 ft·lbf @ 2500 rpm Valvetrain : SOHC 3 valves + 1 auxiliary valve for each cylinder Fuel Control : Carbureted, CVCC, CVCC was not equipped on Canadian CDM cars Known as the EW-2 from 84-86 [edit] D15A3 Found in: 1985-1987 Honda CRX Si and 1987 Civic Si (AU/NZ) Displacement : 1488 cm³ Bore and Stroke : 74 mm X 86.5 mm Compression : 8.7:1 Power : 91 hp (68 kW) @ 4800 rpm & 93 ft·lbf @ 3500 rpm Valvetrain : SOHC, 3 valves/cylinder Fuel Control : Fuel Injected, Multi-point PGM-FI [edit] D15B VTEC Found in: 1991-1999 Honda Civic VTi EG4 (Japanese Market) Displacement : 1493 cm³ Bore and Stroke : 75 mm X 84.5 mm Rod Length : 137 mm Compression : 9.3:1 Power : 130 hp (97 kW) @ 5800 rpm & 102 ft·lbf @ 4200 rpm Redline : 7200 rpm Fuel Cut : 7411 rpm Valvetrain : SOHC VTEC Head Code : P08 (same head as D16Z6) Fuel Control : OBD-1 MPFI [edit] D15B (with 3 stage VTEC) 3-stage VTEC Found in: 1996-1999 Honda Civic VTi EK3 and Ferio Vi Displacement : 1493 cm³ Bore and Stroke : 75 mm X 84.5 mm Rod Length : 137 mm Compression : 9.3:1 Power : 130 hp (97 kW) @ 5600 rpm & 102 ft·lbf @ 3800 rpm Valvetrain : SOHC VTEC Fuel Control : OBD-2 MPFI [edit] D15B1 (Same as the D15B2 engine, but with a mild camshaft, and a restrictor plate between the throttle body and intake header) Found in: 1988-1991 Honda Civic Hatchback Displacement : 1493 cm³ Bore and stroke : 75 mm X 84.5 mm Compression : 9.2:1 Power : 70 hp (52 kW) @ 4500 rpm & 83 ft·lbf @ 3000 rpm Valvetrain : SOHC (4 valves per cylinder) Fuel Control : OBD-O DPFI [edit] D15B2 Found in: 1988-1991 Honda Civic DX/DLX 1988-1991 Honda CRX DX 1992-1995 Honda Civic LSi Hatch/Saloon (European Market) 1990-1995 Honda Concerto (European Market) Displacement : 1493 cm³ Bore and stroke : 75 mm X 84.5 mm Compression : 9.2:1 Power : 91 hp (68 kW) @ 4900 rpm & 119 Nm @ 3800 rpm Valvetrain : SOHC (4 valves per cylinder) Cam Gear : 38 tooth Fuel Control : PGMFI Dual Point Redline : 7000 rpm [edit] D15B4 Found in: 1989-1991 Honda Civic GL (Australian Market) Displacement : 1493 cm³ Bore and stroke : 75 mm X 84.5 mm Compression : 9.2:1 Power : 90 hp (70 kW) @ 5200 rpm & 122 Nm @ 3800 rpm Valvetrain : SOHC (2-4 valves per cylinder, depending on year) Fuel Control : Dual Carburettor [edit] D15B6 Found in: 1988-1991 Honda CRX HFx Displacement : 1493 cm³ Bore and Stroke : 75 mm X 84.5 mm Compression : 9.1:1 Power : 62 hp(88-89) 72 hp(90-91)@ 4500 & 83 ft·lbf @ 2800 rpm Valvetrain : SOHC (2 valves per cylinder) Fuel Control : OBD-0 MPFI [edit] D15B7 Found in: 1992-1995 Honda Civic CX (Canadian model) 1992-1995 Honda Civic DX/LX 1993-1995 Honda Civic del Sol S 1992-1995 Honda Civic LSi Coupe (European Market) Displacement : 1493 cm³ Bore and Stroke : 75 mm X 84.5 mm Compression : 9.2:1 Power : 102 hp (76 kW) @ 5600 rpm & 98 ft·lbf @ 3800 rpm Valvetrain : SOHC (4 valves per cylinder) Piston Code : PM3 Fuel Control : OBD-1 MPFI [edit] D15B8 Found in: 1992-1995 Honda Civic CX (U.S. model) Displacement : 1493 cm³ Bore and Stroke : 75 mm X 84.5 mm Compression : 9.1:1 Power : 70 hp (52 kW) @ 4500 rpm & 83 ft·lbf @ 2800 rpm Valvetrain : SOHC (2 valves per cylinder) Fuel Control : OBD-1 MPFI [edit] D15Z1 VTEC-E Found in: 1992-1995 Honda Civic VX 1992-1995 Honda Civic VEi (European Market) Displacement : 1493 cm³ Bore and Stroke : 75 mm X 84.5 mm Rod Length : 137 mm Compression : 9.3:1 Power : 92 hp (69 kW) @ 5600 rpm & 97 ft·lbf @ 4800 rpm Valvetrain : SOHC VTEC-E (2 valves per cylinder) Piston Code : P07 Fuel Control : OBD-1 MPFI [edit] D15Z4 Found in: 1996-2000 Civic Exi and SA Ballade & Civic 150i Displacement : 1493 cm3 Power : 50hp @ 5800 rpm Torque (ft·lbf@rpm): 99 (135 N·m) @ 4200 rpm Valvetrain : SOHC non-VTEC 16v [edit] D15Z6 VTEC-E Found in: 1996-2000 Honda Civic LS (European Market) Displacement : 1493 cm³ Bore and Stroke : 75 mm X 84.5 mm Rod Length : 137 mm Compression : 9.6:1 Power : 115hp @ 6500 rpm Torque : 100 ft·lbf (141 Nm) @ 4800 rpm VTEC Switchover : 2500 rpm (3500 rpm in 5th gear) Valvetrain : SOHC VTEC-E (2 valves per cylinder) Fuel Control : PGM-FI MPFI [edit] D15Z8 VTEC-E Found in: 1996-2000 Honda Civic LS (European Market) Displacement : 1493 cm³ Bore and Stroke : 75 mm X 84.5 mm Compression : 9.1:1 Power : 84 kw (114 hp) @ 6500 rpm Torque : 134 Nm (95 ft·lbf) @ 5500 rpm [edit] D16 Series Engines (1.6 Liters) [edit] D16A1 Found in: 1986-89 Acura Integra (USA) Displacement : 1590 cm³ Bore and Stroke : 75 mm X 90 mm 1986-1987 Compression : 9.3:1 1988-1989 Compression : 9.5: 1 1986-1987 Power : 113 hp (84 kW) @ 6250rpm Torque : 99 ft·lbf @ 5500rpm 1988-1989 Power : 118 hp (88 kW) @ 6250rpm Torque: 103 ft·lbf @ 5500rpm Valvetrain : DOHC non-VTEC Piston Code 1986-87 : PG6 Piston Code 1988-89 : P29 (PM7 is ZC equivalent/same piston) Fuel Control : OBD-0 MPFI [edit] D16A3 Found in: 1986-89 Acura Integra (Australia) Displacement : 1590 cm³ Bore and Stroke : 75 mm X 90 mm Compression : 9.5:1 Power : 118 hp (88 kW) @ 5600 rpm & 103 ft·lbf @ 4800 rpm Valvetrain : DOHC Fuel Control : OBD-0 MPFI [edit] D16A6 Found in: 1988-1991 Honda Civic Si, CRX Si, Civic Wagon RT4WD 1990-1991 Honda Civic EX Sedan 1988-1995 Honda Civic Shuttle RT4WD (UK/Europe/Asia/AU/NZ) 1989-1996 Rover 216/416 GSi (UK/Europe) Displacement : 1590 cm³ Bore and Stroke : 75 mm X 90 mm Compression : 9.1:1 Power : 115 hp (86 kW) @ 5600 rpm & 95 ft·lbf @ 3,800 rpm, redline 6500 rpm (USA) Note: 1988 engines were 105 hp (78 kW), MY89-91 hp was increased to 108 Valvetrain : SOHC Fuel Control : OBD-0 four-point PGM-FI Head Code : PM3 Piston Code : PM6 [edit] D16A7 Basically a D16A6 that came without a catalytic converter, like the European version of the D16A6.ex US 4 Door Found in: 88-95 Models in South Africa Ballade SH4 and SR4 ( D16A7 / EE4 ) Displacement : 1590 cm³ Bore and Stroke : 75 mm X 90 mm Compression : 9.6:1 Power : 115hp @ 5900 rpm & 100ft·lbf @ 4800 rpm Valvetrain : SOHC Fuel Control : OBD-0 Multi-point PGM-FI [edit] D16A8 Found in: 1988-1991 Civic/CRX/Concerto (UK/Europe/Australia) 1990-1995 Rover 216/416 GTi(UK/Europe) Displacement : 1590 cm³ Bore and Stroke : 75 mm X 90 mm Compression : 9.5:1 Power : 125 hp (93 kW) @ 6800 rpm & 108 ft·lbf @ 5900 rpm Valvetrain : DOHC Fuel Control : OBD-0 MPFI ECU Code: PM7 [edit] D16A9 (Same as D16A8 but without a catalytic converter) Found in: 1988-1991 Civic/Concerto (UK/Europe) 1988-1991 CRX (UK/Europe/South Africa) 1989-1996 Rover 216/416 GTi (UK/Europe) 1992-1995 Civic Si (Peruvian version) Displacement : 1590 cm³ Bore and Stroke : 75 mm X 90 mm Compression : 9.5:1 Power : 130 hp (97 kW) @ 6800 rpm & 108 ft·lbf @ 5900 rpm Valvetrain : DOHC Fuel Control : OBD-0 MPFI ECU Code: PM7 GearBox : L3 Cable type [edit] D16Y3 Found in: 1995-1997 Honda Civic MB1 LS (UK/Europe) Displacement : 1590 cm³ Power : 115 hp (86 kW) @ 5600 rpm, redline 6500 rpm Valvetrain : SOHC [edit] D16Y5 VTEC-E Found in: 1996-2000 Honda Civic HX 1996 Honda Civic EX(sedan Peruvian version) Displacement : 1590 cm³ Bore and Stroke : 75 mm X 90 mm Compression : 9.4:1 Power : 115 hp (86 kW)@ 5600 rpm & 100 ft·lbf @ 4500 rpm Valvetrain : SOHC VTEC-E Fuel Control : OBD-2 MPFI Head Code : P2J 1996-2000 VTi (Phils. & NZ) Displacement : 1590 cm³ Bore and Stroke : 75 mm X 90 mm Compression : Power : 127 hp (95 kW)@ 5800rpm Valvetrain : SOHC VTEC-E Fuel Control : OBD-2 MPFI Head Code : P2J ECU Code : P2M Piston Code : P2MY [edit] D16Y7 NON VTEC Found in: 1996-2000 Honda Civic DX/VP/LX/CX 1999 Honda Civic Special Edition - SE(Canada) 1996-97 Honda del Sol S Displacement : 1593 cm³ Bore and Stroke : 75 mm X 90 mm Compression : 9.4:1 Power : 105 hp (78 kW) @ 5600 rpm Torque (ft·lbf@rpm): 95 (141 N·m) @ 3,800 rpm Valvetrain : SOHC Fuel Control : OBD-11 MPFI Head Code : P2F Piston Code : P2E [edit] D16Y8 Also available in New Zealand under the code D16Y6 VTEC Found in 1997-1998 Honda Civic EX Sedan 1996-1998 Honda Civic EX Coupe 1996-2000 Honda Civic EX (USDM) 1996-2000 Honda Civic SI (Canada Only) 1996-2000 Acura 1.6EL (Canada Only) 1996-1997 Honda del Sol Si Displacement : 1590 cm³ Bore and Stroke : 75 mm X 90 mm Compression : 9.6:1 D16Y8 1.6 16V SOHC VTEC-II PGM-FI 1590 127 hp@6600 rpm 108tq@5500 rpm Head Code : P2J Piston Code : P2P Redline 7200 rpm VTEC switchover : 5200 rpm [edit] D16Y9 Found in: 1996-2000 Honda Ballade and Civic in South Africa Displacement : 1590 cm³ Bore and Stroke : 75 mm X 90 mm Compression : 9.2:1 Power, Torque : {{Auto hp120 / 89kw} @ 5900 rpm 146nM @ 4000 rpm Valvetrain : SOHC, 4 valves per cylinder non - VTEC Fuel Control : Fuel Injection [edit] D16Z5 (Basically the same engine as the D16A9, but now with a catalytic converter and lamda sensor) Found in: 1988-1992 Honda CRX (European Market) Displacement : 1590 cm³ Bore and Stroke : 75 mm X 90 mm Compression : 9.5:1 Power : 124 hp (92 kW) @ 6800 rpm Valvetrain : DOHC Cam Gear : 34 tooth Fuel Control : OBD-0 PGM-FI Head Code : P7 Piston Code : PM7 ECU Code: PM7 [edit] D16Z6 Found in 1992-1995 Honda Civic (ex/si) 1993-1995 Honda Del Sol Si (only USDM) Displacement : 1590 cm³ Bore and Stroke : 75 mm X 90 mm Compression : 9.2:1 Power : 125 hp (93 kW) @ 5800 rpm & 106 ft·lbf @ 4500 rpm Redline : 7200 rpm Fuel Cut : 7411 rpm Valvetrain : SOHC VTEC Fuel Control : OBD-1 MPFI Head Code : P08 ECU Code : P28 [edit] D16Z9 Found in: 1995-1997mmmm Power : 126 hp (94 kW) Valvetrain : SOHC VTEC [edit] D17 Series Engines (1.7 Liters) [edit] D17A1 Found in: 2001-2005 Honda Civic DX/LX/VP Displacement : 1668 cm³ Bore and Stroke : 75 mm X 94.4 mm Compression : 9.5:1 Power : 115 hp (86 kW) @ 5600 rpm & 110 ft·lbf @ 4500 rpm Valvetrain : SOHC Fuel Control : OBD-2 MPFI [edit] D17A2 VTEC-E Found in: 2001-2005 Honda Civic EX 2001-2005 Honda Civic Si (Canada only) Displacement : 1668 cm³ Bore and Stroke : 74.98 mm X 94.4 mm Compression : 9.9:1 Power : 127 hp (95 kW) @ 5800 rpm & 114 ft·lbf @ 4800 rpm Valvetrain : SOHC VTEC-E Fuel Control : OBD-2 MPFI [edit] D17A6 VTEC-E Found in: 2001-2005 Honda Civic HX Displacement : 1668 cm³ Bore and Stroke : 75 mm X 94.4 mm Compression : 9.5:1 Power : 125 hp (93 kW) @ 5800 rpm & 111 ft·lbf @ 3800 rpm Valvetrain : SOHC VTEC-E Fuel Control : OBD-2 MPFI [edit] D17A7 Found in: 2004-2005 Honda Civic GX Uses CNG (Compressed Natural Gas) Displacement : 1668 cm³ Bore and Stroke : 75 mm X 94.4 mm Compression : 12.5:1 Power : 115 @ 5800 rpm & 98 ft·lbf @ 3800 rpm Valvetrain : SOHC Fuel Control : OBD-2 MPFI Partager ce message Lien à poster Partager sur d’autres sites
