sinox 0 Posté(e) le 13 juillet 2014 " />" />bonjour voila g mis le testeur 12.4 ha a la baterie 12.3 ha a la masse et au + a mon amplis je pense que 12.4 ha a la baterie c trop faible et sa et le test etais fais sans l amplis allume et oqp a jouer j imagine en pleine puissance le crois que je descend a 9 ha voir 8 ha g un aplis fusion fiche technique de mon amplis.Brand New - PowerPlant Monoblock Amplifier 3000 Watts - D-Class PP-AM3000100dB - 12dB Bass Boost @ 45Hz20Hz-350Hz Frequency Response (-3dB)40A X 4 Fuse Rating20K Input Impedance0.2V - 8V Input Sensitvity3000 Max Power Rating (Watts)850 Watts RMS X 1 Channel @ 4 Ohms:1300 Watts RMS X 1 Channel @ 2 Ohms:1500 Watts RMS X 1 Channel @ 1 Ohm>80dB Signal To Noise1% (100Hz) THD @ Rated Power6dB / Octave Variable Low Pass Filterfiche technique caisson.Rockford Fosgate P3-1X12 Loaded 12" Subwoofer EnclosureRockford Fosgate's 12" vented subwoofer enclosure has a peak power rating of 1200 watts and an RMS rating of 600 watts. This enclosure comes equipped with one 12" Rockford Fosgate P3D2-12 dual 2 ohm subwoofer that are constructed with a anodized aluminum heat sinking cone material and a santoprene rubber surround. The subwoofer are loaded into high quality 5/8" MDF vented enclosure that is covered in durable black carpet. This package will enhance your cars audio system immensely.The Rockford Fosgate Subwoofer has Dual 2 Ohm Voice Coils; internally wired in parallel down to a final impedance of 1 Ohm. For more information regarding subwoofer wiring, please check out our Subwoofer Wiring DiagramProduct Features12" Punch P3 Series Dual 2 Ohm SubwooferPower Handling:Peak: 1400 wattsRMS: 700 wattsImpedance: 2 ohmAnodized aluminum heat sinking cone & dustcap for strength and durabilityTall profile true Santoprene vertical attach surround technique increases a speaker's effective radiating cone areaDual tear & fatigue resistant linear poly cotton spidersOptimized motor magnetics with extended pole and bumped backplateFatigue resistant and reduced strain stitched tinsel leadsMulti point high temp/strength neck joint bonding techniqueSturdy 16 gauge compound bend frame geometrySemi-Flexible PVC removable protective motor coverCustom insulated compression input terminal assemblyProprietary spider venting/cooling techniqueDecorative die cast trim ringCustom 10-AWG nickel plated push terminalsHigh temperature 4-layer 2-1/2" voice coil with spun laced nomex insulating reinforcement collarDouble stacked ferrite magnet structureSubwoofer has been internally wired to a final impedance of 1 ohmFrequency response: 26.5-250 HzSensitivity: 85 dBXmax: 16.2 mmMounting Depth: 6-11/16"Cutout Diameter: 11-1/4"1-year Manufacturer's warranty Partager ce message Lien à poster Partager sur d’autres sites
sinox 0 Posté(e) le 13 juillet 2014 qui c me dire le probleme svp Partager ce message Lien à poster Partager sur d’autres sites
sinox 0 Posté(e) le 13 juillet 2014 [img][/img]pourriez vous de dire a koi sert le reglage de mon amplis et comment puis-je les regler pour que mon amplis se me pas en secu Partager ce message Lien à poster Partager sur d’autres sites
marcoclub-tunix 0 Posté(e) le 20 juillet 2014 MP à Dirk peut etre ^^ (power dd concept) Partager ce message Lien à poster Partager sur d’autres sites
delicar1 0 Posté(e) le 29 juillet 2014 bonjour les 12ha à mon avis tu as voulu dire 12 volt????12,4 volt si ton testeur est bien étaloné et pas un testeur bon marché ??12,4 volt moteur allumé ou eteind ??? a mon avis voiture eteinte ???l'ampli se coupe quand tu augmente le volume cela proviens du manque de courant as tu bien mit ta masse quand je dit bien c'est sur la carrosserie et la carrosserie poncé jusqu'a la tole ????quel section de cable as tu utilisé de la batterie a l'ampli ????6²,10²,16²,25²,50² ????batterie d'origine ou au gel????avec un ampli de 1500 watts rms une batterie d'origine est insufisante inutile de mettre un condo un condo mise a part l'esthétique cela ne sert a rien ...pour les réglages on règle un ampli a l'osciloscope , je me doute que peux en possède un on peux aussi le faire au multimetre cela permet un réglage a environ 90% des capacité de l'ampli je dirai environ 52 volt en sortie (si ma mémoire est bonne)pour que ton réglage soit +- correct imput level au 3/4 (meme un peux plus )lpf a fond (c'est le réglage qui limite les fréquence de sortie de l'ampli a fond tu ouvre toute les fréquence)subsonic a zéro (un simulateur de basse on va dire)boost a zéro (un destructeur de sub on peux l'utilisé légèrement mais avec un réglage présci) tu vas me dire oui mais quand je met du basse boost ca va plus fort je te dirai c'est faud et c'est facilement verifiable avec un term lab tu shoot avec le bass boost et sans tu verras ton score sera mieux sans boost c'est une fausse impréssion que l'oreil donne l'impession que cela va plus fort est due a la distortion causé par le sub voila j'espere que cela t'aidera .mais ton ampli coupe a 90% a cause d'une mauvaise allim retire le fusible a l'avant et essaye en direct sur la batterie et je suis casi persuadé que ton ampli ne coupera plus cela voudra dire que les cause sité plus haut sont réel attention ne pas joué sans fusible par la suite cela sert uniquement pour le test Partager ce message Lien à poster Partager sur d’autres sites
sinox 0 Posté(e) le 15 septembre 2014 merci oui sa m aide car hiere g mis USB test de maximus SPL sa commansais a sentir le bruller jonathan(maximux spl) ma dit de ts diminuer subsonic et boost,sur sertain forum lp freq il me dise de le retire si je le met sa risque pas de me peter le sub? Partager ce message Lien à poster Partager sur d’autres sites
delicar1 0 Posté(e) le 15 septembre 2014 lpf ca rique pas de cassé les sub c'est le volume et la distortion ou surpuissance qui casse le sub Partager ce message Lien à poster Partager sur d’autres sites
