benjy1
code défaut erreur ecu honda
Fault Codes Explained
This page explains what each of the PGM-Fi fault codes means, the implications on operation of the ECU when running under the fault condition, and comments on typical causes for the fault.
To read how to obtain fault codes from your vehicle, please take a look here.
1
Oxygen Sensor "A" (Primary)
Honda say Defective circuit or unplugged / defective sensor.
Implications ECU will probably not run in closed loop operation.
Comment With OBD-0 VTEC ECU's such as the PW0 and PR3 that run two primary oxygen sensors (one for each pair of cylinders) make sure you have the correct sensor in the correct manifold boss!
2
Oxygen Sensor "B"
Implications To follow.
Comment More details to follow. Secondary oxygen sensor's purpose is typically to monitor the performance of the catalytic converter.
3
MAP Sensor (Manifold absolute pressure)
Comment To follow, please see details for fault code 5.
4
CKP Sensor (Crankshaft position)
Comment To follow.
5
Honda say Defective circuit or unplugged / defective sensor / incorrect pipework.
Implications ECU will run TPS based routine.
Comment The MAP sensor is the primary load input, and on failure the ECU will run some form of substitution based on the TPS input. Engine will run, although generally not idle and performance is severely impaired. Do not run the engine any longer than required to get the car to a repair shop.
6
ECT Sensor (Engine coolant temperature)
Implications ECU will ignore the input if it is not within range, and substitute a fixed value.
Comment Fixed value substituted when input is not in range varies depending on engine RPM - commonly 85°C during normal operation, although this is raised during cranking.
7
TP Sensor (Throttle position)
Comment Incorrect adjustment or failure of the TPS sensor or wiring issues will cause a number of problems, mainly idle related. Details of adjustment procedure to follow.
8
TDC Sensor (Top dead centre)
Comment To follow.
9
CYP Sensor (Cylinder position)
Comment To follow.
10
IAT Sensor (Intake air temperature)
Comment Details of fixed value used to follow.
11
IMA Sensor (Idle mixture adjust)
Implications Probably substitution of fixed value if input is not within range.
Comment Sometimes known as the CO Pot. This is fitted to OBD-0 ECU's in some vehicles that do run an lambda sensor. This only applies to some some markets, like the UK where fitting of a catalytic converter was not law until 1991. The input is simply a potentiometer that is used to trim the base fuelling - hence the name CO pot.
12
EGR Lift Sensor (Exhaust gas recirculation)
Implications Unknown.
Comment EGR is used for emission control.
13
BARO Pressure Sensor (Atmospheric pressure sensor)
Comment This sensor is commonly fitted with US and European ECU's, it is not normally found on JDM units. With OBD-0 ECU's this sensor is external to the ECU and on all later units (including OBD-0 VTEC ecu's such as the PW0) it is a small module fitted internally to the PCB.
14
IAC Valve (Idle Air Control)
Honda say Defective circuit or unplugged / defective valve.
Comment Only applies to vehicles equipped with an automatic transmission.
15
Ignition Output Signal
Honda say Missing or defective ignition output signal.
Comment To follow.
16
Fuel Injector System
Comment Problem with fuel injectors.
17
VSS (Vehicle Speed Sensor)
Implications If engine is VTEC model, it will not be engaged.
Comment Early 1990 VSS sensors as fitted to B series engined MK2 Integra's and MK2 CRX's are prone to failure - the design was modified and late 1991-onwards vehicles rarely get VSS problems.
18
Ignition Timing
Honda say Unknown.
Comment Not quite sure about this one!
19
Automatic Transmission Lock Up Control Solenoid Valve
Honda say Defective circuit or unplugged / defective solenoid valve .
20
ELD (Electrical Load Detector)
Comment This is a solid-state hall effect current sensor, commonly mounted in the engine compartment's fuse box (normally located on top of a suspension turret) and it's purpose is to monitor current demand for precise emission control.
21
VTEC Solenoid Valve
Honda say Defective circuit or unplugged / defective solenoid valve.
Implications VTEC will not be engaged, no high cam lobes.
Comment Solenoid, or "spool" valve that allows oil to flow into the VTEC mechanism. VTEC will obviously not operate and engine will feel breathless at higher RPM's. High RPM driving should be avoided as the engine will only be operating on the low speed lobes.
22
VTEC Oil Pressure Switch
Honda say Defective circuit or unplugged / defective pressure switch.
Comment This switch was only used on early VTEC engines - note it is not to be confused with the oil pressure switch. Commonly caused by idiots who don't check their oil level - so if it flashes up during hard cornering or braking then stop and immediately and check the dipstick! The VTEC mechanism is operated hydraulically from the engine's main oil supply and when it is first engaged causes a momentary fluctuation in oil pressure, and demand on the pump - if pressure available to the VTEC mechanism is not high enough, it will disable VTEC.
23
KS (Knock Sensor)
Honda say Defective circuit or unplugged / defective pressure sensor.
Comment ECU will be unable to trim ignition timing to adapt for differing environmental conditions, and quality of fuel.
30
Automatic Transmission Signal "A" SEAF / SEFA / TMA or TMB
Comment To follow.
31
Automatic Transmission Signal "B"
Comment To follow.
41
Primary Oxygen Sensor - Heater
Comment To follow.
43
Fuel Supply System
Comment This is generally flagged when the engine is running either very rich, or lean due to a mechanical problem, or very bad tuning. Based on Lambda sensor input to some extent. Get a wideband AFR meter on the car - also check your injectors and fuel pressure.
43
Fuel Supply System
48
LAF Sensor (Lean Air Fuel)
Comment To follow.
54
CKF Sensor (Crankshaft Speed Fluctuation)
Comment This sensor is mounted behind the timing belt sprocket on the crank, and used to closely monitor the speed of the crank to detect a misfire etc. Only fitted to OBD-2 systems.
58
TDC Sensor 2 (Top Dead Centre)
Comment To follow.
61
Oxygen Sensor, Heated - Sensor 1 (Primary)
Honda say High voltage, low voltage or slow response.
Comment To follow.
63
Oxygen Sensor, Heated - Sensor 2 (Secondary)
Comment To follow.
65
Oxygen Sensor Heater (Secondary)
Comment To follow.
67
Catalyst System Efficiency Below Threshold
Honda say Malfunctioning or defective catalyst system.
Comment To follow.
70
Honda say Malfunction with the automatic transmission controls.
Comment To follow.
71
Cylinder 1 Missfire or a Random Missfire
Honda say A condition is present that is creating a cylinder misfire.
Comment To follow.
72
Cylinder 2 Missfire or a Random Missfire
Comment To follow.
73
Cylinder 3 Missfire or a Random Missfire
Comment To follow.
74
Cylinder 4 Missfire or a Random Missfire
Comment To follow.
75
Cylinder 5 Missfire or a Random Missfire
Comment To follow.
76
Cylinder 6 Missfire or a Random Missfire
Comment To follow.
80
Exhaust Gas Recirculation
Honda say Insufficient flow detected.
Comment To follow.
86
ECT Sensor (Engine Coolant Temperature)
Comment To follow.
90
Evaporative Emission Control System
Honda say Leak detected in the fuel tank area.
Comment To follow.
91
Fuel Tank Pressure Sensor
Honda say Low input.
Comment To follow.
92
Honda say Insufficient purge flow.
Comment To follow.
CODES ERREURS ECU HONDA
Nombre de clignotements Cause
1 Capteur d'oxygène
2 ECU
3 et 5 Pression absolue de collecteur d'admission (MAP)
4 Capteur d'angle de vilebrequin
6 Capteur de température d'eau
7 Capteur d'angle de papillon
8 Capteur d'angle de vilebrequin PMH (TDC)
9 Capteur d'angle de vilebrequin
10 Température d'air à l'admission
11 Réglage défectueux du mélange au ralenti
12 Système de recirculation des gaz d'échappement (EGR)
13 Pression atmosphérique (PA)
14 Contrôle d'air électronique (EACV)
15 Pas de signal d'allumage
16 Injecteur d'essence
17 Capteur de vitesse du véhicule (VSS)
18 Réglage défectueux de l'allumage
19 Soupape à solénoïde de contrôle de de verrouillage (transmission automatique)
20 Détecteur de charge électrique (ELD)
21 Soupape à solénoïde de bobine (VTEC)
22 Contacteur de pression d'huile de calage variable (VTEC)
23 Capteur de cliquetis
30 Signal "A" : Unité de contrôle ECM injection (transmission automatique)
31 Signal "B"
35 Signal repos TC (Legend)
36 Signal FC TC (Legend)
41 Chauffage de capteur d'oxygène ou LAF
43 Système d'alimentation essence
44 Système arrière d'alimentation essence (Legend)
45 Système d'alimentation déréglé : trop riche ou trop pauvre
47 Pompe à essence
48 Capteur LAF
50 Capteur de débit d'air
51 Soupape à solénoïde de bobine arrière (Legend)
52 Connecteur de pression d'huile arrière de calage variable
53 Capteur de cliquetis
54 Capteur d'angle de vilebrequin
58 Capteur n°2 TDC (V6)
59 Position de cylindre n°1
61 Capteur avant d'oxygène : réponse lente
63 Capteur arrière d'oxygène : tension anormale
65 Capteur arrière d'oxygène défectueux
67 Inefficacité du pot catalytique
70 Boîte automatique
71 Raté d'allumage cylindre n°1
72 Raté d'allumage cylindre n°2
73 Raté d'allumage cylindre n°3
74 Raté d'allumage cylindre n°4
75 Raté d'allumage cylindre n°5
76 Raté d'allumage cylindre n°6
80 EGR défectueux
86 Capteur de liquide de refroidissement
90 Contrôle du système d'évaporation du réservoir d'essence
91 Capteur de pression du réservoir d'essence
92 EVAP contrôle de purge
