sebseb1111 0 Posté(e) le 22 mars 2015 Bonjour à tousje cherche pour augmenter mes performances de freinage sur ma voiture des freins arrière type rs2.En effet j'ai un train arrière de s2 avant alors si quelqu'un a des pistes d'évolutions ou éventuellement un kit je suis preneur.seb Partager ce message Lien à poster Partager sur d’autres sites
Stef19 0 Posté(e) le 24 mars 2015 http://www.s2central.net/brakes_05.htmlAvant / Sedan Variant -On the Avant or Sedan models, due to the different handbrake mechanism, it is possible to use the full sized 300mm disc from the 8E0 chassis (listed above) along with the intended NeuS4 calipers (8E0 615 423/424 C) , carriers (8E0 615 425B ) and pads (4B3 698 451).These can only be used on the Coupe if there is a solution to the handbrake cable problem - hydraulically they fit up perfectly. One important point on the NeuS4 caliper is that a funky hydraulic hose is required ( 8E0 611 775H) - fortuitously it has the same sized fitting where it joins the hard brake lines. It doesn't hurt to replace the union clips at this stage (4D0 611 715B). Minor modification of the hole that locates the handbrake cable on the neu caliper is required for the avant/sedan cable - just needs enlarged a little. This upgrade has been successfully performed by a few members on the S2forum. Partager ce message Lien à poster Partager sur d’autres sites
sebseb1111 0 Posté(e) le 28 mars 2015 Bonjour merci pour ce lienje vais regarder ca .seb Partager ce message Lien à poster Partager sur d’autres sites
