MONTELESON
petite question toute con
j'ai un poste pioneer DEH-P8000R et je ne sais pas si la façade s"enlève car je n'ai pas le bouquin et je n'arrive pas à trouver sur internet, de m'aiguiller car ça me pacontent .
* Supertuner III™️ with RDS (Radio Data System)
* 24-Station/6-Button (18FM/6AM) Presets
* BSM (Best Stations Memory)
* AGC (Automatic Gain Control) for Optimum CD Tracking Performance
* Playback Compatible with Digital Audio CD-R (when Disc is Finalized)
* IP(Interactive Pioneer)-Bus System Control
o 6, 12, & 50+1 Multi-CD Players
o Component Single-CD or -MD Players
o Voice Commander (CD-VC60)
o TV Tuner (GEX-P7000TV)
* Disc Title Memory (48 Discs)
* CD-Text Decoder (for use with CD-Text encoded CD’s)
* 10-Character Display for Disc Title Memory, CD Text (SCD & MCD) & MD Title (with Scroll)
* Disc List
* MOSFET45 (45Wx4-Channel High Power)
* Hi-Volt RCA Preouts (x3 pair) (Front/Rear + Subwoofer or Non-Fading) (Non-Clipping 4.8V max)
* Two-Way Crossover (HPF & LPF)
o Front/Rear HPF (50/80/125Hz, -12dB/Oct.)
o Sub-Out LPF (50/80/125Hz, -18dB/Oct.)
o Sub-Out Level (-12dB to +12dB) and Phase Control
* EEQ Performance Chip
o 3-Band Parametric Equalizer
o Easy EQ (EEQ) switches 5 Factory, 1 User EQ Presets (Super Bass, Powerful, Natural, Vocal, Flat, Custom)
o Source Custom EQ Memory
o Selectable Loudness Control (Low/Mid/High/Off)
o Selectable FIE (Front Image Enhancer) (Rear LPF 100/160/250Hz)
* AUTO-Flap Motorized Face
* Detachable Face Security™️
* DFS™️ Alarm
* Wireless Full-Function Smart Remote Control (with Mounting Base)
* Cellular/Navigation Mute (Cellular Mute Requires Optional CD-CM1)
* New Multicolor Organic EL Display
o Full Motion Animated 3D Graphics
o High Resolution Display (256 x 52 pixels)
o Super Bright (60 candela) with Wide Viewing Angle (170 degrees)
* Level Indicator
6eme point en remontant vers le haut ! comprendre facade detachable securisee !
En appuyant sur le bouton open normalement ta facade bascule ! a ce moment la tu tires vers toi la facade quiest positionne sur des glissieres ! autrement je vois pas le truc !
desole je ne peux pas t'aider plus je suis dans le brouillard au niveau son ! mur
en basculent ta fassade tire doucement vers toi et vers la droite ou la gauche si elle est detachable c est la seul solution bonne chance.
moi sur mon pionner DEH 6900IB, j'ai un système antivol qui permet de laisser la façade sur le poste, peut être que c'est le même style de système qui fait que t'arrive pas à enlever la façade
sinon essai d'enlever le poste complet de son logement, et tu verras si il y a pas des pattes de fixation de la façade sur le poste
merki aurélien, j'ai téléchargé le manuel , mais ils ne parlent pas pour enlever la façade et je n'ai pas les clef pour enlever le poste complet car il été déjà dans la voiture
ta façade bascule vers toi? si c'est le cas il faut soit la déclipsé sur la gauche ou la droite en tirant légérement......
pour sortir l'autoradio, tu enlèves le contour en plastique autour de la façade
et tu utilise 2 tournevis, un pour faire un espace entre l'autoradio et la console et l'autre pour aplatir les pattes du tiroir antivol
j'en ai déja sortir plusieurs comme ça
oui pas besoin d'avoir les clé spécifiques ou si tu veux moi je les sort avec 2 pinces a ongles , tu prends la petite lame et hop le tour et jouer.....ensuite je viens de voir une photo de comment ta façade bascule et c'est vrai que c'est bizarre ton système...je vais voir ce que je trouve
