cesium
Autoradio-dvd retractable Kenwood KVT 725DVD(nouveau prix!)
KVT-725DVD
7.0" In-Dash Monitor, Receiver, DVD/MP3/WMA Player
General- Features
• 7.0 inch Wide Colour TFT Active Matrix Display
• Number of Pixel: 336,960 pixels
• Screen Size: W154.1mm x H87,1mm
• Full-automatic Open/Close Mechanism
• Motorized Tilt Angle Adjust (8 Step)
• Motorized Back & Forth Display Position adjust ( 4 positions)
• Interactive Touch Panel Control with On Screen Display (OSD)
• Multifunction Key Operation
• DVD Disc Menu Direct Touch Operation (Highlight Ciontrol Mode)
• Audio Easy Control Mode
• Partial Detachable Theft Detterent Faceplate (TDF)
• Security Code Function & Disabled System Indicator (DSI)
• External Hard-Key Operation ( When Monitor is Closed)
• Selectable Key Illumination (Green/Red)
• Amplifier Control System
• 1-way Telephone/Navigation Mute
• TV reception with optional TV Tuner
• Digital Clock (24H)
• Remote Control Unit Supplied
• All-in-one
Audio/Video Features
• Maximum Output Power : 50W x 4 (MOSFET Power IC)
• 3 RCA Preouts with 5V Pre-output Level (Front/Rear/Subwoofer)
• 1 RCA AV Output (PAL or NTSC according to the source)
• 1 RCA AV Inputs (PAL/NTSC Automatic Selection)
• 1 RCA Video Input with Mirror MOde Function for Rear View Camera
• Video Input Signal Automatic Detection Mode (Normal/ Auto)
• RGB Input for optionel Navigation System
• System Q (Preset Sound Control)
• Dual Zone Source & Volume Control
• Attenuator(-20dB) with Smooth Volume Return
Tuner features
• FM/MW/LW 24 Station Presets (18FM, 6MW & LW)
• RDS with Radio Text
• Up/Down Seek Tuning
• Local Seek
• FM Stereo/Mono Selector
DVD/CD Features
• DVD Video Player
• DVD ± R/RW Compatible (Video Format Only)
• VCD Compatible
• WMA (Windows Media Audio) Decoder
• MP3 Decoder with ID-3 Tag Display
• MPEG 1/2 Video File (.mpg)
• CD Text Ready
• CD-R/CD-RW Compatible
• Direct Access with Remote
• Random/Repeat/Scan Play
Changer features
• Dual Disc Changer Control Capability (CH1/CH2 & AUX)
• DNPS (Disc Name Presets) with Compatible CD Changers
• DNPP (Disc Name Preset Play) by Remote
• CD Text Ready with Compatible CD Changers
• Random/Repeat/Scan Play (Disc/Track)
Etat impeccable - pas une griffe - Disponible de suite.
Vendu dans sa boite d'origine, avec tous les documents,fiches,cablages,...
Prix : 800 euros.
Renseignements: Cesium21@teledisnet.be ou 0495/68.68.95
Le prix peut être legerement a discuter, néanmoins il est justifié vu l'état de l'appareil, la qualité du matériel, le prix à l'achat,... .
Hello, comme je t'ai dis sur le message, si tu décide de baisser ton prix, pense a moi, mais se prix là ,c'est pas pour moi !tu as mon num
Fais moi une offre raisonnable via mail et je te dirai quoi!
Mac Fly a écrit:
Y a quelque chose de détachable contre le vol???
Oui, toute la partie inférieure de l'autoradio...
bonjour moi je suis tres interaiser par le poste juste le prix qui ma un peut refroidis je t ai fait une proposition via mail
Je viens de reply à l'instant ...
Suite désistement, l'objet est remis en vente... Le prix comme indiqué ci-dessus est négociable mais bon pour m'en proposer 300 euros mieux vaut s'abstenir!
L'appareil est dispo de suite, car il est déjà demonté de la voiture et ranger dans sa boite d'origine.
P.S Bien sur, je le rebrancherai pour montrer le bon fonctionnement de l'appareil au vendeur...
c combien le dernier prix
focusman a écrit:
Possibilité de montage dans une Focus? Avec les commandes au volant?
Desole de repondre si tardivement, mais je viens juste de recuperer internet.
Pour le montage, pas de prob dans une focus, ca passe sans problème! Concernant les commandes au volant, c'est possible de les recuperer mais il faut acheter un petit boitier additionel chez Kenwood. Ce boitier est spécifique a la ford focus pour utiliser a 100% les commandes au volant ( Si c'est le meme système que chez VW)
Quel serait ton offre ??
Suite changement de projet, je remets mon autoradio-dvd en vente ...
Pour le prix : 650 euros
Comme un projet urgent se présente, je diminue mon prix de vente à 550 euros...
P.S Les personnes qui m'ont contactés auparavant, je n'ai plus vous coordonnées donc si toujours intéressés, contactez moi via mail ou tel.
mail : cesium21@teledisnet.be
Tel : 0495/68.68.95
